News
No defects in PS3 stamping parts, says maker
Published on November 21, 2006
Taiwan-based G-Shank Enterprise stated that stamping parts it manufactured for Sony's PlayStation 3 (PS3) game consoles have no defects and should not cause malfunction of the console's card reader, according to a November 20 filing the company made with the Taiwan Stock Exchange (TSE). Read more
Supply of high-density NOR flash said to be tight
Published on December 05, 2005
In addition to supply trailing demand for low-density parts, the NOR flash memory market is experiencing tight supply of high-density parts (above 8 Mbit) from the two leading makers, Intel and Spansion, and the situation is not expected to ease until the first quarter of 2006, according to industry players. Read more
DDR2/DDR price gap narrows to 5 percent
Published on June 30, 2005
The DDR2 512Mbit price premium over DDR 512Mbit has shrunk to 5%, down from 30% in the beginning of 2005, and DRAM supply is expected to run short of demand as memory makers continue to shift production to NAND flash. Read more
Intel releases BTX-compatible products for channel sales
Published on November 16, 2004
Intel yesterday introduced a series of BTX (Balanced Technology Extended)-compatible products, including boxed processors, thermal modules, motherboards, chassis and power supplies in Taipei. Read more
Latest Reviews & Articles
Acoustically Manage Your Hard Drive
Published on December 09, 2008
Most modern drives can be set to deliver maximum performance or to operate quietly. We looked at how performance, acoustics, and power requirements change when switching from fast to quiet using Hitachi’s Deskstar 7K1000.B. Read more
Graphics Boosted: 790GX's Side-Port Explored
AMD's 790GX and 780G support onboard memory to help improve the performance of integrated graphics. Is it worth paying a bit extra or is the feature a mere gimmick? Read more
PCI Express & CrossFire: Scaling Explored
Published on December 08, 2008
Does your aging CrossFire-compatible motherboard have enough PCI Express bandwidth to make a second card worthwhile? We compare every Core 2-based platform in order to find out. Read more
Intel SS4200-E: PC-Based NAS Evaluated
Published on December 05, 2008
Intel's Celeron-based SS4200-E is the company's latest effort to clinch market share in the SOHO storage space. Is it enough to usurp more established incumbents? Read more
  Tom's Hardware Forums » Homebuilt Systems » New System Build » Are these parts compatible?
Word :   Username :
Bottom
Author
 Thread : Are these parts compatible?
Profile: stranger
More Information
Hello! I am planning to build a gaming computer for my husband for Father's Day. I have done some research and have read a lot of the forum posts here (they helped a lot....thanks), but I wanted to run this build by everyone before buying the components. My husband will be playing UT3 and I will be doing some light photo editing and general internet stuff.
Please let me know what you think of the components I have selected and if you think there is something else that may work better. I am hoping everything will fit in the case. I am pretty sure I have the correct Mhz, but maybe I am not seeing something right. Oh, I am trying to stay around $1000 or so (not including gaming keyboard, mouse, monitor and OS).
So here is what I have picked out so far:
APEVIA X-CRUISER-GN Green Steel ATX Mid Tower Computer Case
Intel Core 2 Duo E8400 Wolfdale 3.0GHz 6MB L2 Cache LGA 775 65W Dual-Core Processor - Retail
EVGA 123-YW-E175-A1 LGA 775 NVIDIA nForce 750i FTW SLI ATX Intel Motherboard - Retail
EVGA 01G-P3-N869-AR GeForce 9600GT 1GB 256-bit GDDR3 PCI Express 2.0 x16 HDCP Ready SLI Supported Video Card - Retail
OCZ GameXStream OCZ700GXSSLI 700W ATX12V Power Supply 100 - 240 V - Retail
Western Digital Caviar SE16 WD5000AAKS 500GB 7200 RPM 16MB Cache SATA 3.0Gb/s Hard Drive - OEM
Thermaltake CL-P0401 110mm Full-Range Fan CPU Cooler - Retail
Patriot Extreme Performance 2GB (2 x 1GB) 240-Pin DDR2 SDRAM DDR2 1066 (PC2 8500) Dual Channel Kit Desktop Memory - Retail
Lite-On LH-20A1L-06 SuperAllwrite Retail Lightscribe DVD Burner - 20x DVD±R Burn, 16x DVD±R Read, Black, SATA
I look forward to any and all help. Thanks so much!
Related Product
WR2
Profile: Faithful Poster
More Information
The parts you picked out all all compatibile and all very good choices (even if one is made of green steel).
That bright copper heat sink fan and it's blue light should look interesting in that green case.
Usually the HSF comes with its own thermal compound or thermal grease. I didnt see any for the CL-P0401 in either the accessory pack or listed in the specs under package contests. Package Contents comparison The Thermaltake website want any help either. Arctic Cooling MX-2 Easy to apply, non-conductive and no curing period.
I was going to suggest you could get the next lower Power Supply but it turns out after rebate the 700W model is less than the 600W model.
Your 9600GT is the most expensive model and at that price is very near the cost of the more powerful 8800GTS (G92) $10 difference after rebate.
Evga 9600GT Models Plus 8800GTS KO Was there any particular reason picking the 9600GT 1GB model over the 8800GTS?
Message edited by WR2 on 05-15-2008 at 12:23:58 AM
Profile: Forum Veteran
More Information
You can save money if you buy an intel mobo. You don't need an sli mobo if you're not going sli. You might say you would down the road, but when? By the time you're ready for a 2nd card, there'll be a new more powerful card for about the same price. A good budget Intel mobo is GA-P35-DS3L for $90. If you don't overclock, the GPU will run at the same speed on DS3L & 750i. If you overclock the cpu, the DS3L might actually beat out the 750i. The only good thing about the 750 is X16 SLI.
I've seen it time & time again that people would buy an expensive SLI mobo and a lacking GPU due to cost. They could have bought a budget mobo + a powerful GPU and run faster in games. Ditch the 750i & pick up GTS512 & you're golden.
Google Ads
