Q9550 @ Striker II extreme OC questions
Forum Overclocking : General Discussions - Q9550 @ Striker II extreme OC questions
I am currently running my Q9550 @ 3.54GHz @ 5:4 ratio (I have 1333 memory)
My temps, during error free prime95 smallFFT test:
max temps: MB: 40 CPU:51 core1/1:56 core1/2:51 core1/3:60 core1/4:53
Vcore on auto at 1.328
Everything seems fine at these settings, but I want to go higher.
I am cooling with a core contact 4
How high can I go? is 1999fsb too high an objective?
What are my limiting factors? only temperature?
Sponsored Links
is it air cooled? the north bridge might get hot. i got my q6600 to 3.8 no problems stock air cooled no errors, i didnt get my vcore that high, i wouldnt recommend going past what the manual says maximum
Reply to jbridges1987
if you need to you should be able to take your Vcore to about 1.49v max!!!
Your temps are absolutely fine, but might be worth running a more comprehensive custom test in Prime. With those temps you can surely go higher and i reckon 4.0GHz (about 1780) should be fine.
Take it in slow steps from then on tho, it all depends on your particular chip, so who knows how high yours will go!
------------------------------ Q6600 @ 3.0GHz | Zalman CNPS9700-NT Titanium Cooler | GA-EP45-UD3P | Sapphire HD4870 1GB | 4GB (2 x 2GB) OCZ PC2-8500C5 1066MHz DDR2 |OCZ GameXstream 600W |
Reply to peaks
1.49 on a Q9550 ? you crazy, its not a Q6600 !
you can get this 9550 @ 3.8 under 1.4 vcore. i dont recommand 1.5 on a 45nm cpu, its pretty high.
------------------------------ __________________________Le Québécois_________________________
WCed Q9550 EO + P5Q @ 3.825ghz / HTPC - E5200 + P5Q @ 3.3ghz
BFG GTX285 OC2 + PC P&C 750w . / HIS HD4850 with Sharp 42" 1080p
Reply to boulard83
My bad. I have a Q6600 and have been so wrapped up in my own oc problems!
Reply to peaks
1.4? Why such a high vcore setting? im running my Q9550 E0@ 3.93 1.31v
Reply to joeman42
mine's 3.91ghz on 1.3V. I wanted to go higher but the fact that i'm using 8gb of ram is not helping with the OC and the northbridge temperature (it's set to 1.5v if i remember correctly). Good thing i'm using the p5q deluxe or else I wouldn't dare to go that high for a northbridge
Reply to yang
Remember guys. The vcore required for a particular frequency is going to depend on the CPU's VID. If you get a chip with a low VID, you have more OC headroom.
Reply to jsc
With the Striker II Extreme Motherboard,
You are your limiting factor, educate yourself, start with the link below.
http://www.anandtech.com/mb/showdo [...] i=3283&p=1
Specifically study the articles (Complete BIOS Tuning Guide)
Message edited by 4ryan6 on 10-21-2009 at 01:47:21 AM
------------------------------ Badges? We don't need no stinkin' badges!
Reply to 4ryan6
Tom's Hardware > Forum > Overclocking > General Discussions > Q9550
There are 950 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
