I have just received and put together new build with the following specs:
Gigabyte GA-EP43-DS3L
Intel Q6600
ZALMAN CNPS9500
2x G.SKILL 4GB (2 x 2GB) DDR2 1000 (PC2 8000)
BFG Tech GeForce 8800 GT 512MB 256-bit GDDR3 PCI Express 2.0
SILVERSTONE ST75F 750W ATX 12V 2.2 & EPS 12V
COOLER MASTER RC-690
Once i booted the system up for the first time it would not post and kept restarting every 10 seconds or so, also the CPU Phase LEDs that this mobo has were all on.
After removing all the non-essentials and reseeding CPU, RAM, Video Card, and clearing the BIOS it posted and I was able to install Vista x64 and reconnect everything back in the case.
The system worked for about a day, while I was testing the new system by playing CS:Source it gave me a IRQ-NOT-LESS-OR-EQUAL BSOD and restarted, after which it now keeps doing what it did after the build.
I tried everything I did last time and still the same happens, a few times it posted and said it was recovering the BIOS after which it continued to restart...the weird thing is that when there is no RAM in the mobo it gives no beep codes and just keeps restarting
I saw many topic relating to Gigabyte boards and this happening that turned out to be a dead board..just want to confirm if that is true or if you guys might have some other ideas.
Thanks.
P.S...there was on OC done, all BIOS values were default.
Intel Q6600
ZALMAN CNPS9500
Thanks.
