Now I started the system up with no real problems, got windows xp installed. Noticed the system was running a little warmer than I was used to but I chalked it up to the extra processing power. I used the system for a couple days without a hitch, with the exception of a few video problems, which I fixed with a driver upgrade.
The problem is that I was gaming tonight, and the system shutdown. Weird. Not shut down as much as powered off. There was a small pop when it happened, and a slight burning smell. I let things cool down a bit, and tried to power the system back up, nothing.
My guess is that the power supply overloaded, and a fuse blew somewhere. Anyone else have a different idea? If this IS the case, how do I go about solving the problem? Any help would be greatly appreciated.
Not quite enough info, but if I had to guess with what you had given me, ide say yes, the power supply blew. The reason I would suspect this is because it was under load when your system crashed. If you have a spare power supply laying round, try it out.
------------------------------"Since the dawn of time, man has dreamed of blotting out the Sun." - J. Montgomery Burns
Reply to hypocrisyforever
well the cpu uses the most power. judging your system i would guestimate 550-600watts. the most. 500watts at least. make sure that' you don't get a cheap one, cause these are the types of porblems that happen. my ocz gamextreme 700watt psu has been running for six months now with no issues. i rarely turn off my computer, if i do it's to swtich os.
Ok, I'll look into that. I just tore the old PS apart, the fuse inside is still intact. After plugging it back in I pressed the power button, and the cpu and case fans moved for a millasecond, and stopped.
Q9450 2.66 12mb cache(6mbx2)
Asus EAH3870/G/HTDi/512Mb
ASUS P5K Intel P35 LGA775 1333FSB Crossfire 2xPCI-16x M/board
OCZ 2Gb Kit (2 X 1Gb) PC2-6400 ATI Crossfire Certified XTC
HUNTKEY TITAN 650 650WATT power
500Gb, 250Gb and 160Gb seagate HDD's
He cannot run 3dMark06 or 06-Vantage no matter what OS we try, but it works with my 8800GT OC2, we sent the card in and asus "fixed" it-it does the same thing, we probably are going to send it in again but i just wondered if there was something we might be missing??
