Tom's Hardware > Forum > Storage > Hard Disks > Low Power 2.5" SATA HDD .Industrial Grade operating temperature range
Forum Storage : Hard Disks - Low Power 2.5" SATA HDD .Industrial Grade operating temperature range
Hi There,
I am looking for a 2.5" SATA HDD which has maximum Power requirement should be less than 1.5W ...Is there any body who has Idea ant this ???
I am also looking for 2.5" HDD which is operating at Industrial Temperature range (-20C to +85C).. I have seen may option but I didn't find any.. Any Idea How I can use HDD at Industtrial grade ??
Best Regards,
RH
Sponsored Links
Not sure about temperature range. You'll have to check the datasheet of individual drives for their ambient temperature tolerance during operation. Usually 0-55C I think.
Otherwise you'll be looking at SSD which is almost bullet proof and won't consume more than 0.8W. The downside with SSD is limited capacity and highish $/GB. >128GB and the price starts going haywire.
The power consumption of todays 2.5" 500GB HDD is at least 1.8W so that doesn't fit your criteria.
Message quoted 1 times
Message edited by wuzy on 08-18-2009 at 01:11:04 PM
------------------------------ GTL Ref Tweaking Guide - PM for detail
Brand is for the weak-minded, only product matters.
Resilient to marketing.
http://farm3.static.flickr.com/2520/3850950213_aea6bbbcfe_o.jpg
Reply to wuzy
Thanks Wuzy for the reply..
I am looking for min 250GB HDD and if I can accomodate even in 1.8W it is great for me but I have seen that all HDD power requirement is Quite higher @ Strat Up..??
Any Idea How to tackle with this ??
Can you suggest any part with max power requirement 1.8W ??
Reply to Rizwanhirani
- 0 +
Why do you need such a low power drive?
------------------------------ Asus P6T deluxe
i7 965 @ 4.2GHz (200*21), 1.384V
12GB Corsair Dominator DDR3-1600 CAS 7
Reply to cjl
Hey man..
Thansk for the interest..
But I want my new design to accommodate in 13W.. total Power consumption.. As I want my design to be operated as powered device on Power over Ethernet.. (not in PoE+)
Other part in my design is crucial & I have minimize the power requirement as far as possible..but still struggling with the power.. so need to reduce power requirement in HDD ??
If you have any Idea .. Please suggest.
- 0 +
Ahh. I really don't see any good way to do that other than an SSD then. Almost any HDD will draw enough power in spinup to cause problems with that small of a power envelope.
Reply to cjl
Oopsss..
I already ruled out solid state drive option for main two factors::
1. Limited Size of the memory Max 160 GB (I am looking for the support up to 500 GB min 250 GB)
2. Cost factor..
Is there any way or any HDD Availabel in which I can controll the speed of spin through the software driver or I put large value bulk capacitor at the power in put of HDD.. so that Current requirement of the HDD for the time of spinnig can be fulfilled with bulk capacitor with tolerable voltage dip in the 5V rail..
means ,
i = C * dV/dt ;
So ,
C= i * dt/dV ;
dV = acceptable voltage dip ;
dt = Spinning duration at stratup -- the periode for which the current requirement is 'i' ;
i = Requirement of current.
Do you find any possibility with this type of design ??
RH
- 0 +
You can get SSDs well over 160GB (though they are quite expensive). Here's an example:
http://www.newegg.com/Product/Prod [...] 6820233085
http://www.newegg.com/Product/Prod [...] 6820609415
As for the capacitor design? It has some promise, yes. It appears that the Toshiba drive has a max draw of 2.05W or so during normal operation, so as long as that is in your capability to run, it would probably work with the capacitor to aid spinup.
Reply to cjl
CJL ,
Any Idea what is the typical time of startup spining for the HDD ?? From where i get this data ?? It will be helpful to me in design ??
- 0 +
To be honest, I don't know. I know someone who probably does know though, so I'll ask them and try to get back to you :)
Reply to cjl
- 0 +
I think a spinup time of about 5 or 6 seconds is pretty typical.
Reply to sminlal
- 0 +
I think it's a lot less than that for notebook drives, honestly. As I said, I know someone to ask who would actually know.
Reply to cjl
- 0 +
I think your only option is SSD, and its not gonna be cheap. You might need to rethink your plan, or bust out the credit card.
Reply to daship
- 0 +
OK, I asked, and it should be around 2 seconds for a 2.5". That temperature range will be an issue though - there aren't any drives on the market other than SSDs that are rated for -20C to 80C+ operation.
Reply to cjl
There are 1096 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
