Ok so I've built a new computer and to some extent it runs, however it seems to be pretty unstable, originally I thought it was a problem with the graphics card so I returned it, but they sent it back saying it passed their tests. So I tried swapping out the new graphics card with my old one, I got the same problems again, so I'm going to say it's safe to say the graphics card is not the problem.
Everything is new in the computer so my next guess is the motherboard is faulty somehow.
Basically what happens is when I boot up I will sometimes make it to windows, however when I get there several things can happen, I could have everything working ok until I try to run a game or something more graphics intensive in which case the screen will flicker and fill up with artifacts until it becomes unusable. Sometimes when I get to windows its as if my drivers weren't installed, Windows Aero doesn't work, little choice in resolutions, etc. Also it seems that my sound drivers don't always load either. When I don't make it to windows my computer sometimes decides for no apparent reason it's going to do a disk check, or it might just restart itself while loading windows.
The problems seem to be alot more apparent when using the 9800GTX as apposed to the x1950 Pro, I'm guessing because the 9800GTX requires more power, resources, I don't know.
Anyways here's the build;
PSU: Tagan BZ Series 800W
CPU: Intel Q9450
RAM: 4x 2GB 6400 800MHz OCZ
Mobo: ASUS P5N-D 750i
GFX: Nvidia 9800GTX
HDD: 3x 500GB (2x SATA II / 1x Ext. USB 2.0)
Display: 37" HANNspree Xv HDTV (connected via HDMI)
Sound: Soundblaster X-Fi
Others:
Belkin Wireless network card
CDRW Drive
Note: I haven't overclocked anything as of yet, I was hoping to do so once I had it all set up though.
CPU: Intel Q9450
GFX: Nvidia 9800GTX
Others:
CDRW Drive
