Hi everyone,
I'm kind of stuck between these two kits.
The Swiftech H20-220 Compact http://www.swiftnets.com/products/h20-220-compact.asp
OR
The Swiftech H20-220 Ultima Plus Kit http://www.swiftnets.com/products/H20-220-APEX-ULTIMA.asp
The reason being is that the compact one will be more compatible with my case (Gigabyte iSolo 210)
and also with the Ultima Kit MY GPU's are blocking leaving very very little space for tubing to get to the pump located at the bottom.
So will the Compact one do a sufficient enough job.
OR
