Having looked thoroughly and becoming extremely confused what's your opinion on my current memory.
I fitted x2 2gig ddr2 modules into the mobo and they were detected and are running fine, my dilemma is do you recommend leaving the settings in bios on automatic as it currently is or manually setting them to the manufacturers specification on the modules which are 5-5-5-18 and 2.1v.
Here is a screenshot of CPUZ currently showing all the necessary info, do I leave as is or manually add the values
