Hey all,
I'm pretty new to this forum. I've been building computers for as long as I can remember, but I've never done any overclocking.
Recently I've been thinking about a new build, with an i7 920 paired with an Asus P6T Deluxe V2. Although then I figured: "If I'm going for a new build soon anyways, why not overclock my current setup and see how it runs?"
....and now I'm here.
I've done some searching here on the forums, and lots of Google searching.
Currently I'm running:
Intel Core2Duo E6600
Asus P5B-E MOBO
Arctic Silver 7 Pro Cooler
6 GB DDR2-800 RAM (Gskill)
XP 32-Bit
I've played with the BIOS a bit, and have entered in my memory timings manually. (running stock auto voltage)
I'm running AUTO voltage for all voltages, and I currently have the FSB set to 361. (x9, so 3249 mhz, 3.25ghz)
My idle temps are around 48C-50C. (The past 3 minutes I've only been typing and they're both at 48C now)
I ran the Intel TAT and set both of my cores to 100% workload. The temps then shot up to around 70C-71C.
My main question is: Are these temps too high?
I just opened up my case again today, and re-seated my Arctic cooler. Previously I was using the "stock" thermal paste that came with the cooler, so today I took the cooler and CPU out, lapped them both, and then applied some Arctic Silver 5. I'm expecting that the temps will drop a bit in a few days, after the thermal paste and lapped CPU have "broken-in". (Though I've been running on stock voltages/speeds for about 2 years now on this setup)
I'm gonna go watch some TV now, and before I leave I'm gonna run Prime95, and see how things turn out. For what it's worth, at stock speeds my idle temps were around 41C earlier. Now that I've lapped the CPU/cooler, and applied Arctic silver, it idles around 35C on stock speeds.
Asus P5B-E MOBO
XP 32-Bit
