Yes No
Ads
Tom's Hardware > Forum > Windows XP > General Discussion > [Solved] Audio In Problem
Forum Windows XP : General Discussion [Solved] Audio In Problem
Best answer from treefrog07.
My onboard Audio is Realtek ALC 662 on ASUS P5S-MX SE motherboard. The output is working
but the inputs (Mic and Line In) are not working. What could be the problem
Reply to Herbwes
Best answer
Open Sound Volume in the system tray to the Advanced View and make sure the Line-in and Mic are enabled.
Reply to treefrog07
You double-posted. :non:
Your question was answer in this post:
http://www.tomshardware.com/forum/ [...] io-problem
If you're going to tell someone where to go, supply a link to get there.
Reply to tigsounds
Hello, my on board audio is Realtek is ALC 662 6 channel. The output is working but the inputs (Mic and line in)are not working. What could be wrong.
Reply to Herbwes
Quote :
What could be wrong
Could it be your mixer is not setup to allow those inputs to enter the sound system?
Some of the Realtek systems have a mixer completely dedicated to output, and another for input.
Double-click sound icon in tray (if you have it there) and look at what the mixer is set to do.
Click Options, Properties, and look for a drop-down box that now says under "Mixer Device" Realtek HD audio Output and click the drop-down box and see if there is a Realtek HD Audio Input that can be selected, and therefore adjusted.
Reply to tigsounds
This next topics has been merged by Aford10
  • Realtek audio in problem
------------------------------ CM HAF 932 / GIGABYTE GA-EP45T-DS3R / E8500 @ 3.75Ghz / 300GB Velociraptor / 4G DDR3 OCZ Reaper 1333
Saphire 1G 4850
Simple and Free Guide to Removing Malware
Reply to aford10
There are 1891 identified and unidentified users. To see the list of identified users, Click here.
Ads
Latest best answer
Password
By ksiemb, 7 hours ago:
Cannot help with password retrieval. - Forum Rules.
Best offers
Top experts
