12 Computers For Christmas
Hope someone can help me out.. I have an ecs kv2 extreme s939 board I went to upgrade the bios but half way through it got a blue screen and crashed. So I used the top had to revert to the old bios it worked fine. After this I installed the new bios successfully I had the computer working fine for awhile I set up cool n quiet for the cpu then I shut the computer down and installed my 2nd hard drive. After this I tried turning the computer on only to find the monitor wouldn't display there was no signal. So I put the top hat back on the bios and the only thing that happens now is the KV2 splash screen. I have tried everything i could think of - flashing cmos, taking out the cmos battery, taking out cmos jumper... I'm lost at this point and had to get out an old pentium 3 450mhz comp that im using now.. please help
nvm i found the problem it was the psu it's bad it fried 2 of my hds now LOL
I have the same problem. I had updated to the new bios version 1.3d and now can't get past the kv2 splash screen. need help.
You are about to answer a thread that has been inactive for more than 6 months.If you still wish to proceed, please ensure that your posting is original and does not duplicate or overlap any prior responses to this thread.
