Tom's Hardware > Forum > Overclocking > General Discussions > E8400 need overclocking help, noob
Forum Overclocking : General Discussions - E8400 need overclocking help, noob
I just bought an E8400 processor and was wondering how I would go about overclocking it, i.e. where to go to change things, what heatsink/fan and voltages to use.
I've been reading a little bit about it and it seems that 3.6 GHZ is safely attained without increasing the voltage or changing the heatsink and fan, which would be just fine for me. Is there much of an advantage or performance difference between kicking up to 4GHZ as opposed to the 3.6GHZ?
I have this motherboard: GIGABYTE GA-EP45-UD3L LGA 775 Intel P45 ATX Intel Motherboard
http://www.newegg.com/Product/Prod [...] -_-text-_-
this memory: G.SKILL 4GB (2 x 2GB) 240-Pin DDR2 SDRAM DDR2 1066 (PC2 8500) Dual Channel Kit Desktop Memory
Thanks for any help you can give.
Sponsored Links
It also looks like the motherboard can support the memory clocked to 1366 MHZ, any help or suggestions on that would be appreciated as well.
Reply to bigmidgeman
Have you read the How To sticky?
------------------------------ *How To Ask For New Build Advice*
HAF 922 | HX750
Rampage2Gene | i7 920 D0 | 6GB Gold 1600 | Hyper 212+
Caviar Black 640GB | HD3870
Reply to theAnimal
No, I'm guessing I should take a look at that.
Thanks for the suggestion, looks like I have a little bit of studying to do.
There are 1056 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
