Archived from groups: microsoft.public.windowsxp.basics (More info?)
Hi, Previously, I was using a microsoft intellimouse and ended up toasting
it because I forgotten to uninstall a driver before I installed the new
driver. So now I have a generic ball mouse and it seems to be doing the
same thing, which is erratic movement, and freezing temporarily. I
uninstalled the driver, rebooted and windows xp professional has
installed the ps2 driver.. Could the problem be the ps2 port? Any help
appreciated... thanks Rainy
(the name on the top of the mouse is PC Concepts) I went to the website
http://www.pcconcepts.com/html/mic_frm.html and found what I think might be
the driver.. it is called USB TO PARALLEL CABLE driver software. which I
have not installed.. not until I find out it is
the correct driver..
thanks!
Rainy
Not quite sure how you toasted a mouse by not uninstalling a driver, but
whatever.. it may not be your mouse that is causing problems.. it could be
bad video drivers or another program running in the background..
You might want to share computer specs too.. lack of memory, an over full
hard drive can also cause the 'jitters'..
Mike Hall
MVP - Windows Shell/User
"Rainy" <rainydays38@sweetwrapz.net> wrote in message
news:UOGLe.267075$xm3.61488@attbi_s21...
> toasting it because I forgotten to uninstall a driver before I installed
> the new driver. So now I have a generic ball mouse and it seems to be
> doing the same thing, which is erratic movement, and freezing
> temporarily. I uninstalled the driver, rebooted and windows xp
> professional has
> be the driver.. it is called USB TO PARALLEL CABLE driver software.
> which I have not installed.. not until I find out it is
thanks!
Hi Mike, thanks for the response.. I got that information about the mouse
from a tech site... I didn't make it up! lol
I have a home built computer. Since it's easier for me to copy the summary
from Aida32.. here is probably more information than you need... You may
have hit on something though, I have always had a yellow X on my Display 3D
Accelerator... when I see the summary from Aida32.. thanks Rainy
here is the website for the accelerator..
http://www.nvidia.com/content/drivers/drivers.asp
Motherboard
CPU Type AMD Athlon XP-A, 2083 MHz (6.25 x 333) 2800+
Motherboard Name Asus A7V8X (6 PCI, 1 AGP, 3 DIMM)
Motherboard Chipset VIA VT8377 Apollo KT400
System Memory 1024 MB (DDR SDRAM)
BIOS Type Award Modular (11/13/03)
Communication Port Communications Port (COM1)
Communication Port ECP Printer Port (LPT1)
Display
Video Adapter NVIDIA GeForce FX 5200 (128 MB)
3D Accelerator nVIDIA GeForce FX 5200
Monitor KDS Avitron AV-7TF (BAA37037966)
Multimedia
Audio Adapter VIA AC'97 Enhanced Audio Controller
Storage
Floppy Drive Floppy disk drive
Disk Drive Maxtor 5T040H4 (40 GB, 7200 RPM, Ultra-ATA/100)
Disk Drive WDC WD200BB-75AUA1
Optical Drive _NEC DVD_RW ND-2500A (DVD+RW:8x/4x, DVD-RW:8x/4x,
DVD-ROM:12x, CD:32x/16x/40x DVD+RW/DVD-RW)
Optical Drive ATAPI CD-RW 52X24 (52x/24x CD-RW)
Partitions
C: (NTFS) 19085 MB (7104 MB free)
D: (NTFS) 39072 MB (17447 MB free)
Input
Keyboard Standard 101/102-Key or Microsoft Natural PS/2 Keyboard
Mouse Microsoft PS/2 Mouse
"Mike Hall (MS-MVP)" <mike.hall.mail@sympatico.ca> wrote in message
news:%23ktmN%23MoFHA.2472@TK2MSFTNGP15.phx.gbl...
> Rainy
> Mike Hall
>> professional has
>> be the driver.. it is called USB TO PARALLEL CABLE driver software. which
thanks!
It is extremely unlikely that the USB to Parallel cable driver has anything
to do with your mouse. This would most likely be drivers for a cable that
has a USB connection at one end and a parallel connection at the other -
used mainly for plugging a printer with only a parallel port into the USB
port of your computer.
I'm guessing that the erratic movement has to do with something running in
the background that is using all your system resources temporarily. See
this article to do some troubleshooting along these lines:
How to troubleshoot by using the System Configuration utility in Windows XP
http://support.microsoft.com/?kbid=310560
Also check for parasites. See this site for more information and links to
free utilities:
http://www.aumha.org/a/parasite.htm
PattyL
Also, turn the mouse over and remove the ball and look to see if the rollers
are covered with lint or threads. That's always great for causing erratic
movement.
> professional has
thanks!
Rainy
General specs are fine, but look into the video driver problem.. that is
what will be causing your mouse to jump around..
What you need to do is establish who manufactures the video card.. the info
supplied makes reference to the chipset, which is used by more than a few
manufacturers.. look at the box that originally contained the card..
Re. your mouse, I have swapped mice around without changing any drivers, and
they always work regardless (other than serial mice)..
Good luck
Mike Hall
news:0BHLe.267173$xm3.266991@attbi_s21...
> 3D
> Motherboard
> Display
> Multimedia
> Storage
> Partitions
> Input
>> Rainy
>> be
>> Mike Hall
>>> professional has
>>> which
thanks!
Hi Mike, I don't have the box... would the video
card be part of the motherboard.. although I specified that I wanted a stand
alone video card.. when I had the pc built... so it should not be ... I have
a drawer in my desk that has all the mfg manuals for everything except the
video card...
and to answer the other person who responded.. I have
adaware and spybot and also spyware blaster and use the first two on a
regular basis.. and 9 times out of 10 I come out clean. I have tried to use
the windows xp troubleshooter and came up empted handed... I think the
problem is with the video card.. just wish I knew who the mfg was... do you
have any suggestions? Rainy ps. I just downloaded Belarc Advisor to see if
it would be more specific .. and I can't even find where the video card
would be...just this minute went through my cd's and found one entitled
Nvidia Ge Force FX 5200... but that could be a wrong driver I downloaded and
installed!
I would really love to fix this problem... If I could be sure
that this driver is the right one.. there has to be a way to find out which
video card I have... please help me to do this.. thanks
news:uiOQY9NoFHA.2152@TK2MSFTNGP14.phx.gbl...
> Rainy
> info supplied makes reference to the chipset, which is used by more than a
> few manufacturers.. look at the box that originally contained the card..
> and they always work regardless (other than serial mice)..
> Good luck
> Mike Hall
>> summary
>> 3D
>> Motherboard
>> Display
>> Multimedia
>> Storage
>> Partitions
>> Input
>>> Rainy
>>> be
>>> full
>>> Mike Hall
>>>> installed
>>>> professional has
>>>> might
>>>> which
thanks!
after I sent in my post I knew it was the wrong one... felt stupid too.. so
thanks for the response... yes I believe the erratic movement has to do with
a video card .. wish I knew the mfg name... and could find the driver..
thanks for the response.. Rainy
"PattyL" <pattyl@XXmvps.org> wrote in message
news
u23GoNoFHA.3936@TK2MSFTNGP10.phx.gbl...
> anything to do with your mouse. This would most likely be drivers for a
> cable that has a USB connection at one end and a parallel connection at
> the other - used mainly for plugging a printer with only a parallel port
> into the USB port of your computer.
> XP
> free utilities:
> PattyL
> rollers are covered with lint or threads. That's always great for causing
> erratic movement.
>> professional has
thanks!
do you know what this is? Nvcpl.dll I just noticed it in startup.. and my
mouse appears to be working great.. I might have taken it out of startup
awhile back... and I think this is a dll that belongs to my video card..
Of course I could be way off..but since I think my video card is Nvidia Ge
Force maybe this is part of it.. and when I took it out of startup.. it
messed up my mouse.. someone please tell me if I'm wrong? or right? Rainy
You know I'm one of those dangerous people who have a little bit of
knowledge..
) lol
> Rainy
> Good luck
> Mike Hall
>> summary
>> 3D
>> Motherboard
>> Display
>> Multimedia
>> Storage
>> Partitions
>> Input
>>> Rainy
>>> be
>>> full
>>> Mike Hall
>>>> installed
>>>> professional has
>>>> might
>>>> which
thanks!
Nvcpl is the control panel for the nvidea card
Sounds like your vid drivers are not installed correctly
Visit Nvidea site Download drivers for FX5200
See section re how to install, follow instructions and reinstall as per
news:0gLLe.25653$084.24625@attbi_s22...
Rainy
> knowledge..
) lol
> > Rainy
a
> > Good luck
> > Mike Hall
mouse
> >> summary
y
Display
> >> 3D
> >> Motherboard
> >> Display
> >> Multimedia
> >> Storage
> >> Partitions
> >> Input
> >>> Rainy
but
could
> >>> be
> >>> full
> >>> Mike Hall
> >>>> installed
be
> >>>> professional has
help
website
> >>>> might
> >>>> which
thanks!
it's the driver I had on the cd.. had to be the right driver... so I
reinstalled it... the mouse was working ok before I did that.. I think..
that the control panel was not loading with windows and when I let it load
the mouse worked ok.. not sure why I needed to reinstall the driver? Just
trying to learn... thanks for the response... Rainy
"DL" <dl@spoofmail> wrote in message
news:eiK3yoPoFHA.2904@TK2MSFTNGP14.phx.gbl...
>> my
>> Ge
> Rainy
>> knowledge..
) lol
>> > Rainy
>> > is
>> > than
> a
>> > card..
>> > drivers,
>> > Good luck
>> > Mike Hall
> mouse
>> >> summary
>> >> ma
> y
> Display
>> >> 3D
>> >> Motherboard
>> >> Display
>> >> Multimedia
>> >> Storage
>> >> Partitions
>> >> Input
>> >>> Rainy
> but
> could
>> >>> be
>> >>> full
>> >>> Mike Hall
>> >>>> installed
> be
>> >>>> professional has
> help
> website
>> >>>> might
>> >>>> which
thanks!
well I just checked my device manager, and I still have the yellow x... so
if anyone has any ideas... please don't hesitate, I have had this yellow x
on my 3d accelerator for months now and would really love to solve the
problem.. thanks Rainy
news:MgMLe.25821$084.5370@attbi_s22...
>>> my
>>> Ge
>> Rainy
>>> knowledge..
) lol
>>> > Rainy
>>> > is
>>> > than
>> a
>>> > card..
>>> > drivers,
>>> > Good luck
>>> > Mike Hall
>> mouse
>>> >> summary
>>> >> ma
>> y
>> Display
>>> >> 3D
>>> >> Motherboard
>>> >> Display
>>> >> Multimedia
>>> >> Storage
>>> >> Partitions
>>> >> Input
>>> >>> Rainy
>> but
>> could
>>> >>> be
>>> >>> full
>>> >>> Mike Hall
>>> >>>> installed
>> be
>>> >>>> professional has
>> help
>> website
>>> >>>> might
>>> >>>> which
thanks!
The driver on the cd is not the current driver.
The best live web video on the internet http://www.seedsv.com/webdemo.htm
NEW Embedded system W/Linux. We now sell DVR cards.
See it all at http://www.seedsv.com/products.htm
Sharpvision simply the best http://www.seedsv.com
>>> my
>>> Ge
>> Rainy
>>> knowledge..
) lol
>>> > Rainy
>>> > is
>>> > than
>> a
>>> > card..
>>> > drivers,
>>> > Good luck
>>> > Mike Hall
>> mouse
>>> >> summary
>>> >> ma
>> y
>> Display
>>> >> 3D
>>> >> Motherboard
>>> >> Display
>>> >> Multimedia
>>> >> Storage
>>> >> Partitions
>>> >> Input
>>> >>> Rainy
>> but
>> could
>>> >>> be
>>> >>> full
>>> >>> Mike Hall
>>> >>>> installed
>> be
>>> >>>> professional has
>> help
>> website
>>> >>>> might
>>> >>>> which
thanks!
Sorry about sending this directly to you... it was an accident..so I am
copying and pasting my text...
Is this the reason I have the yellow X? if not I'm going to leave well
enough alone.. everything seems to be working ok now.. plus on the nvidia
site they said I had to uninstall the driver I have now.. before I can
install the new one.. which is what I thought we had to do before installing
a new driver.. at least for this driver you do. Actaully the mouse is
working better than it has for months and months... so thanks to all that
have helped... Rainy
"pcbutts1" <pcbutts1@seedsv.com> wrote in message
news:5cNLe.885$Z%6.658@newssvr17.news.prodigy.com...
>> load the mouse worked ok.. not sure why I needed to reinstall the driver?
>> Just trying to learn... thanks for the response... Rainy
>>>> my
>>>> startup
>>>> card..
>>>> Ge
>>> Rainy
>>>> knowledge..
) lol
>>>> > Rainy
>>>> > is
>>>> > the
>>>> > than
>>> a
>>>> > card..
>>>> > drivers,
>>>> > Good luck
>>>> > Mike Hall
>>> mouse
>>>> >> summary
>>>> >> ma
>>> y
>>> Display
>>>> >> 3D
>>>> >> Motherboard
>>>> >> Display
>>>> >> Multimedia
>>>> >> Storage
>>>> >> Partitions
>>>> >> Input
>>>> >>> Rainy
>>>> >>> driver,
>>> but
>>> could
>>>> >>> be
>>>> >>> over
>>>> >>> full
>>>> >>> Mike Hall
>>>> >>>> installed
>>>> >>>> to
>>> be
>>>> >>>> professional has
>>> help
>>> website
>>>> >>>> might
>>>> >>>> software.
>>>> >>>> which
thanks!
No problem, check your email.
news:Q4OLe.267995$xm3.9872@attbi_s21...
> installing a new driver.. at least for this driver you do. Actaully the
> mouse is working better than it has for months and months... so thanks to
> all that have helped... Rainy
>>> driver? Just trying to learn... thanks for the response... Rainy
>>>>> and my
>>>>> startup
>>>>> card..
>>>>> Nvidia Ge
>>>>> it
>>>> Rainy
>>>>> knowledge..
) lol
>>>>> > Rainy
>>>>> > that is
>>>>> > the
>>>>> > than
>>>> a
>>>>> > card..
>>>>> > drivers,
>>>>> > Good luck
>>>>> > Mike Hall
>>>> mouse
>>>>> >> summary
>>>>> >> You ma
>>>> y
>>>> Display
>>>>> >> 3D
>>>>> >> Motherboard
>>>>> >> Display
>>>>> >> Multimedia
>>>>> >> Storage
>>>>> >> Partitions
>>>>> >> Input
>>>>> >>> Rainy
>>>>> >>> driver,
>>>> but
>>>> could
>>>>> >>> be
>>>>> >>> over
>>>>> >>> full
>>>>> >>> Mike Hall
>>>>> >>>> up
>>>>> >>>> installed
>>>>> >>>> to
>>>> be
>>>>> >>>> professional has
>>>>> >>>> Any
>>>> help
>>>> website
>>>>> >>>> think
>>>>> >>>> might
>>>>> >>>> software.
>>>>> >>>> which
thanks!
There are 700 identified and unidentified users. To see the list of identified users, Click here.
