Power Supply Rec
Add a reply
 Word :   Username :
Bottom
Author
 Thread : Power Supply Rec
Profile: stranger
More Information
Building a new system with the following Specs:
Q9450 Intel Quad
Asus Rampage Formula x48 ddr2
4gb ram 2x2gb
hd4870 - 1 starting out 2 in about 3-6 months in CF
2 HDs 7200rpm Satas
5 case fans 120mm
1 dvd+/-RW
1000 Smart UPS between the comp and the wall.
My extreme power supply calc came out to 653w @ 100% load. I used hd 3870x2 in cross fire since they don't have the site updated for the 4800 cards yet. This was also @ 100% load with an over clock to 3.2 vcore 1.4 setting.
I am looking at PC P&C 750 silencer and wondering if it would do the trick? Would it be a good buy to last 3 years or so?
I am looking for a recommended PS for hd4870 in CF. Pref with out modular cableing and a single 12v rail. I would like it to be under 200USD if possible.
Thanks for any help.
Message edited by anubis1134 on 06-27-2008 at 08:10:55 PM
Related Pr oduct
A brave man may fall but he cannot yield...
Profile: addict
More Information
The PC P&C 750 silencer is a very good unit made of premier quality components, can hardly go wrong with that one...... I am no expert in the matter though but I am pretty sure it'll run your up coming rig just fine. You don't hear people complaining about those unit that much.
Gigabytes 35C-DS3R | C2D 6850 |
Antec 900 | 4 X 2 Gig of DDR2 1000 G. SKill
Sapphire 4870| Corsair 620
Thermalright Ultima 90 + panaflo
Profile: stranger
More Information
Yeah I hear only good things about PC P&C units, I just wanted to know if it will drive my box or if I need to up the watts.
Add a reply
Google Ads
