I'm not a huge stickler for brands on video cards. Personally I'd just buy whatever is less expensive. However, I have never heard of "Point-Of-View" before. I've owned 2 Leadtek GeForce 6800's in the past and both still function. So I'd personally lean that direction.
Others may have a different opinion.
------------------------------i5-750 @ 2.66Ghz / Gigabyte GA-P55-UD4P / Xigmatek HDT-S1283 (Waiting for Bracket)
2 x MSI GTX 260 Core 216 SLI (655Mhz) / 4GB GSkill DDR3 1600 9-9-9-24 @1.5v
2 x WD Caviar Black 1TB / Thermaltake Armor BWS8003
Win 7 64bit / Antec TPQ-850
Reply to jerreece
The Point-Of-View has higher stock clocks, so I guess that would be better. I've never heard of them, but that might be a regional thing, they just might be sold in he U.S. (I don't know where you found this brand...)
Well, I guess they are sold here in the U.S. I've found a model that has higher clocks than the Leadtek and one with the same. So, if the one you are looking at is the same clock as the Leadtek go with the Leadtek. If it's higher, the I guess the P.O.V. would be better...
