Tom's Hardware Forums » Graphic & Displays » Nvidia » can some1 plz help? 8800gtx problems
Add a reply
 Word :   Username :
Bottom
Author
 Thread : can some1 plz help? 8800gtx problems
Profile: stranger
More Information
have
hp m7570.uk
single 3.4 ghz cpu
2gig of ram DDR2
1280x1024 monitor
8800gtx
windows media center edition 2002
Motherboard
Manufacturer: Asus
Motherboard Name: P5LP-LE
HP/Compaq motherboard name: Emery2-UL8E
not sure about PSU manufacturer but its 550watt
i am having framerate problems with my 8800 gtx. i get around 50 fps in counter strike source until i get into a big firefight and it drops down to below 20 fps! i have all the ingame graphics settings on low and set the card to high performance in nvidia control panel and i have the latest drivers for my 8800gtx. surely i should be getting more from my card as i got around the same fps with my 8600gt!!! can someone please tell me what i need to increase my cards performance ?
Related Pr oduct
Profile: Faithful Poster
More Information
CPU bottleneck.
Profile: enthusiast
More Information
My first guess is your 550 watt power supply. while it my be 550 watt i doubt it has the amps to drive the 8800gtx properly. Get a new PSU if possible with at least 32amps on the 12v rail.
This or better
http://www.newegg.com/Product/Prod [...] 6817139004
Also setting the nvidia control panel to let the 3d application decide the quality
Profile: member
More Information
I had the same thing happen to me with my old HP when i upraded to a 7900gs last year. Just unplug any drive or card that you don’t use or need and it mite help out.. A good PSU is always a great investment
and will pay for it self in operating cost over time.
Robert Wilensky:
We've all heard that a million monkeys banging on a million typewriters will eventually reproduce the entire works of Shakespeare. Now, thanks to the Internet, we know this is not true.
Profile: Honorary Poster
More Information
PSU, not enough power, and yes your processor is a very slow match for an 8800GTX. It's not going to run a 8800GTX up to nearly it's full potential.
Profile: stranger
More Information
i opened up my pc today and looked at the power supply, and on the +12VDC it says max output 36A then next to that the -12VDC has 0.8A max output. if im not wrong that should be good enough then if i need 32amps on the 12V rail?
Add a reply
Google Ads
