News
CES 2007: CarMD finds the problem, then tells you what parts and labor should cost
Published on January 09, 2007
Two crappy things in this world: (1) Your car breaking down and you not knowing why; and (2) going to get it fixed and being charged an arm, a leg and some other essential regions in order to get it fixed. Read more
No defects in PS3 stamping parts, says maker
Published on November 21, 2006
Taiwan-based G-Shank Enterprise stated that stamping parts it manufactured for Sony's PlayStation 3 (PS3) game consoles have no defects and should not cause malfunction of the console's card reader, according to a November 20 filing the company made with the Taiwan Stock Exchange (TSE). Read more
Supply of high-density NOR flash said to be tight
Published on December 05, 2005
In addition to supply trailing demand for low-density parts, the NOR flash memory market is experiencing tight supply of high-density parts (above 8 Mbit) from the two leading makers, Intel and Spansion, and the situation is not expected to ease until the first quarter of 2006, according to industry players. Read more
3D Systems drops price of 3D printer below $15,000
Published on March 01, 2006
3D printing is not quite what we would call a mainstream application, but the creation of realistic plastic models of products using a "printer" is becoming more popular with more businesses, product and marketing managers, designers and engineers as well as universities. Read more
Latest Reviews & Articles
Radeon HD 4830: High-Speed, Cheap CrossFire
Published on December 11, 2008
AMD recently launched its Radeon 4830 to take on Nvidia's GeForce 9800 GT. With PowerColor and Sapphire flavors in single- and CrossFire-configurations, we pitch the card against factory-overclocked 8800 GTs and see who is left standing. Read more
Acoustically Manage Your Hard Drive
Published on December 09, 2008
Most modern drives can be set to deliver maximum performance or to operate quietly. We looked at how performance, acoustics, and power requirements change when switching from fast to quiet using Hitachi’s Deskstar 7K1000.B. Read more
Graphics Boosted: 790GX's Side-Port Explored
AMD's 790GX and 780G support onboard memory to help improve the performance of integrated graphics. Is it worth paying a bit extra or is the feature a mere gimmick? Read more
PCI Express & CrossFire: Scaling Explored
Published on December 08, 2008
Does your aging CrossFire-compatible motherboard have enough PCI Express bandwidth to make a second card worthwhile? We compare every Core 2-based platform in order to find out. Read more
  Tom's Hardware Forums » Homebuilt Systems » New System Build » Got all the parts, now what!? ;-)
Word :   Username :
Bottom
Author
 Thread : Got all the parts, now what!? ;-)
Profile: stranger
More Information
I've just ordered the following parts for my first scratch build machine. :-) First, and foremost, of all I'd like to thank everybody for all the help, comments, reviews, etc. in helping with up with this system. I'm sure you've saved me countless hours of trouble and second guessing after the sale.
Before getting into putting it together I though I might ask if anyone had any suggestions before, or as I get started that might save me hassles in the future.
I'm planning on RAID 1 (mirror) config and allocating a small portion of the HD to Ubuntu so I'll also want a dual boot partition. From snooping around I think I at least want to make sure the motherboard bios is up to date. Probably won't worry about over clocking until I get things running smoothly. To run Ubuntu maybe I should just put it on an old IDE and change the HD Boot Priority when I want to run it.
What's the difference between the GIGABYTE SATA2 & the 'regular' SATA2 ports?
Intel Core 2 Quad Q6600 Kentsfield 2.4GHz LGA 775 Quad-Core Processor Model BX80562Q6600 - Retail
GIGABYTE GA-EP35-DS3P LGA 775 Intel P35 ATX Dynamic Energy Saver Ultra Durable II Intel Motherboard - Retail
OCZ Reaper HPC Edition 4GB (2 x 2GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Dual Channel Kit Desktop Memory Model OCZ2RPR800C44GK - Retail
BFG Tech BFGE88512GTSE GeForce 8800GTS (G92) 512MB 256-bit GDDR3 PCI Express 2.0 x16 HDCP Ready SLI Supported Video Card - Retail
Seagate Barracuda 7200.11 ST3750330AS 750GB 7200 RPM SATA 3.0Gb/s Hard Drive - OEM
CORSAIR CMPSU-650TX 650W ATX12V / EPS12V Power Supply - Retail
SAMSUNG 20X DVD±R DVD Burner with LightScribe Black SATA Model SH-S203N - OEM
Microsoft Windows Vista 64-Bit Home Premium for System Builders Single Pack DVD - OEM
https://secure.newegg.com/NewVersio [...] ost+System
Related Product
Lord of the Duck Clan
Profile: Faithful Poster
More Information
Best idea is what you said: install Ubuntu on a separate hard drive outside the RAID.
No idea on the other question, hopefully someone else has that answer :)
http://www.tomshardware.com/forum/ [...] ate-modode <-- Computer Builds
Success comes from knowing that you did your best to become the best that you are capable of becoming."-John Wooden
Ironhide: Why are we fighting to save the humans?
Profile: nimble knuckle
More Information
GSATA ports(purple) come from the onboard gigabyte sata+ide device.
The other 6 yellow sata ports come from the SouthBridge (ICH9R).
If you want RAID1 you can use either as I think the gigabyte sata device supports RAID1 but I'm not sure about the boot capability on those so stick with the yellow ports to be sure.
General advice (in case you need it).
Take it slow and gentle, read the insturctions and regulary touch the case if you don't have an ESD bracelet.
1. Install CPU in motherboard.
2. Install CPU Heatsink on motherboard.
3. Install PSU in case (you can also do this after point 5. It's easier in some cases).
4. Install motherboard standoffs in case
5. Install motherboard into case. Don't overtighten the screws.
6. Install hard and optical disk drives into case
7. Connect SATA cables to disk drives.
8. Install graphics card and any additional cards you might have.
9. Connect power cables to disk drives.
10. Connect the PCIE power
11. Connect ATX/EPS cables to motherboard.
12. Connect USB, power switch, reset switch, power LED(nine hundred doesn't have this one I think), HDD LED cables and SATA cables to the motherboard.
13. Recheck everything is mounted and wired correctly.
14. Plug power cord into PSU and wall socket, connect monitor, keyboard, mouse, speakers...
15. Flip PSU switch and push the power on button.
Good luck.
Message edited by Andrius on 05-21-2008 at 12:55:41 PM
Google Ads
