Tom's Hardware Forums » Motherboards & Memory » Gigabyte » EP35 DS3R BIG PROBLEMS HELP PLEASE
Word :   Username :
Bottom
Author
 Thread : EP35 DS3R BIG PROBLEMS HELP PLEASE
Profile: stranger
More Information
i newley bought this mobo and i setted up and i was using my hardsik in achi mode in my old intel mobo as usually i wanted to use my hdd in achi mode in the ep35 ds3r i enabled all achi functions in bios and inserted my vista setup dvd and formated the hdd and the setup didn't saw my hdd the sata cables was pluged in to the purple ones (which this mobo have two) i installed the driver of sata raid drive and after it saw the hdd and i clicked the setup and the set up gave me an erorr it says windovs could not determine if this computer contains a valid system value. it gave this error while teh hardisk is reachable in setup. after this is pulged the sata cables and plugged them to the other sata ports which is orange but i also installed drivers of the sata in setup but it gave the same problem when i pressed reset the system gave me an error BOOTMGR i don't know what is this after this i closed all achi modes is made them ide and i connected the sata cables first to purple ones the eror didn't changed after i tried orange ones it didn't made any changes it gave the eror again after this i resetted the bios over the mobo and tried to setup windovs it worked it vista is working but when i tried again to use achi mode it gave same error i reseted the bios again and setted up vista. in the windovs actually i installed all drivers of the mobo after the clean format after insattling mobo drivers i installed my graphic card driver nvidia 175.19 version. it installed and i reset the comp to activate driver but while in the welcome screen the display goess off i thought taht there might be an error in the graphic card driver and i installed a lower version which is 175.16 and the display goess off in the welcome screen again after this i reseted the computer and started vista in safe mode and uninstalled the drivers and it is working now but it is working standart as standar graphic card what shold i do. i am really getting angry with this because i am trying to fix it since 2 days but no result. ohh alos tried to install xp in achi mode ofcourse i installed the sata sata2 chip drivers from floppy in xp it copied files but when the xp starts it gave the same eror again BOOTMGR please help me what is the problem what should i do.
Model Name : GA-EP35-DS3R(rev. 2.1)
M/B Rev : 2.1
BIOS Ver : f2
Serial No. :
Purchase Dealer :
VGA Brand : MSI Model : NX8600GT-T2D256E-OC
CPU Brand : Intel Model : D945 Speed : 3,4
Operation System : Vista 32-bit SP :
Memory Brand : Type : DDRII
Memory Size : 2GB Speed : 533MHZ
Power Supply : 400 W
samsung 120IJ harddisk
samsung 250hj hasrddisk
Related Product
Profile: stranger
More Information
Use the orange SATA ports over the purple ones as they are natively attached to the ICH. Enabling AHCI is fine and it sounds like you had the right Intel drivers installed for it to work. Here's a little something I found on another forum which may fix your BOOTMGR issue:
1. Put the Windows Vista installation disc in the disc drive, and then start the computer.
2. Press a key when you are prompted.
3. Select a language, a time, a currency, a keyboard or an input method, and then click Next.
4. Click Repair your computer.
5. Click the operating system that you want to repair, and then click Next.
6. In the System Recovery Options dialog box, click Command Prompt.
7. Type Bootrec.exe, and then press ENTER.
8. Type /FixMbr and enter exit setup and the computer will reboot
The /FixMbr option writes a Windows Vista-compatible MBR to the system partition. This option does not overwrite the existing partition table. Use this option when you must resolve MBR corruption issues, or when you have to remove non-standard code from the MBR.
Google Ads
News
SD cards in tight supply due to Toshiba production problems
Published on December 27, 2004
The supply of Secure Digital (SD) flash-memory cards is currently falling short of growing demand as Toshiba may be experiencing some production problems for its SD modules, according to sources with DRAM-module makers in Taiwan. Read more
Microsoft fixes critical IE problems
Published on December 14, 2005
Microsoft this week fixed a widely reported flaw in its Internet Explorer browser that had been used by attackers over the past few weeks to take over the PCs of unsuspecting users. Read more
E-voting worries focus on failures, not fraud
Published on November 10, 2006
Major electronic voting machine problems occurred in at least six U.S. states during the country's midterm elections, underscoring that system failure, not fraud, is the biggest issue facing future races, voting-rights activists and technologists said this week. Read more
Microsoft patches 20 security holes in February update
Published on February 14, 2007
Microsoft's monthly security update for February has gone live. Though it marks the first update since the consumer release of Windows Vista, none of the 20 fixes are for the new operating system. Read more
Latest Reviews & Articles
Seagate's 1.5TB Barracuda: Bigger And Better?
Published on October 02, 2008
Seagate is the first hard drive vendor to offer a 1.5 TB drive in the 3.5” form factor. Meanwhile, WD sent us its RAID Edition 3 (RE3) drive. We tell you which is the best HDD choice today. Read more
Updated CPU Charts 2008: AMD Versus Intel
Published on October 01, 2008
The processor is the heart of your PC, and our updated charts for Q3 2008 show 54 of them competing in terms of performance. Using our updated suite of benchmarks, compare your favorite AMD and Intel CPUs after reading this introduction. Read more
Stalker: Clear Sky - Is Your System Ready?
Published on September 30, 2008
Thinking about picking up the latest update to Stalker, but not sure if your graphics subsystem can handle it? Hang on as we take you through a performance tour and demonstrate how the game has been prettied up. Read more
Part 4: Avivo HD vs. PureVideo HD
Published on September 29, 2008
The 780G chipset/Radeon HD 3200 and the MCP78S chipset/GeForce 8200 provide the first integrated graphics solutions that can accelerate Blu-ray playback. We dig deep into how well they work with high-quality Blu-ray 1080p video playback. Read more
