Tom's Hardware > Forum > Graphic & Displays > Graphics Cards > Frustrating graphics problem
Forum Graphic & Displays : Graphics Cards - Frustrating graphics problem
Well were do i start aha,
couple of weeks ago my xfx 680i motherboard stopped working, i couldn't be bothered to do all that warranty rubbish so i chucked it in the bin and got an abit fatality FP-IN9 sli motherboard put my 9600gt (that i have only had for like 3 months) in the motherboard, everything was all cool for like a 2 days then i installed some games and they didnt run and distorted my screen the screen was had pixelated dots all over and the it err it was like this for a 3 weeks then i installed some windows updates and did a virus scan deleted some trojans and suddenly i was able to watch movies without the screen flickering or getting pixelated and i could also run one game "Turok 2008" it runs real smooth but i cant run any other game and if ii try to run any other game system freezes have to end the proccess and the my screen gets really pixelated again. i have a screenshot of what happens if it will help anyone come to a conclusion.
thanks for any help i get and for taking the time to help me fix my problem
Sponsored Links
i cant help you, but this is one of the reasons i dont get sli boards.
Reply to pcgamer12
More info on the system please.
Overclocked?
Have you checked temps?
Have you checked error logs?
What are your system specs?
------------------------------ Maximus Formula | q9550@3.6 | 4 GB Kingston HyperX @1106 5-5-5-15-2t | Zalman 9700 | Silverstone 750 | Sapphire 3870x2 | Visontek 3870 OC | 500 GB Vista 32 OS | 74 GB Raptor RAID0 | 74 GB Raptor RAID1 |Samsung SATA DVD | X-Fi Fatal1ty | Thermaltake Armor
Reply to firebird
sounds like video card is overheating or overclocking the gpu too far.
Reply to Shadowthor
You deleted trojans and now its good, but not good? Id recheck to see if you still dont have malware in your system
------------------------------ I went drifting, thru the capitols of tin, where men cant walk and cant freely talk, and sons turn their fathers in
Reply to jaydeejohn
Try a format and fresh reinstall (and a decent antivirus, I recommend KAV) and if the problem continues, post again with more info.
Also post sys specs and temps.
------------------------------ Upgrading sig...
35% Done
Critical Error
Reply to SirCrono
I can't help him either due to him not making much sense. Obviously there's something embedded somewhere that should not be. It's not hardware related, unless he's describing video ram failure, which doesn't seem to be the case, more like codec failure.
But what is that reason you don't get SLI boards? I find SLI boards without SLI are not only no more expensive but have more room around key areas and generally better tempered for thermal management. Including the bonus that large single slot card cooling solutions don't impact your other add-in cards and you can usually use the largest CPU HSF towers as well.
It's a true computer irony.
Reply to bf2gameplaya
lol well i didnt know how much more detail you needed in there
e6300 @ stock - 43
9600gt @ stock - 46
Maxtor 160 ide HD - 49
2gb 667mhz ram - ?
as you can see temps are fine no overclocking either i will try a fresh install and i hope that works
Reply to Anonymous
49 degrees C for your HDD at idle? That seem awfuly high. I've seen lots of HDD temps and none have ever been that high.
I'm looking at the temp for my 500GB Seagate and it's @38, which is high for me.
I see quite a few "max temps" @ 55 degrees for HDDs.
How'd you get stuck with a Maxtor anyway?
Reply to firebird
There are 1340 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
