Hi this is my first PC build from scratch. I have done a ton of mods and helped friends with there pc build before but never done my own from scratch. I am a gamer and a 3d /Photoshop user and need a good system for both. I will be overclocking it but not sure how high I can go safely. Here is what i have kinda decided on for parts I am open to suggestions:
Case: COOLER MASTER Stacker RC-832-KKN1-GP Black Aluminum ATX Full Tower Computer Case - Retail
Motherboard: ASUS Striker II Formula LGA 775 NVIDIA nForce 780i SLI ATX Intel Motherboard - Retail
Vdeo card: (2) MSI NX8800GTS 512M OC GeForce 8800GTS (G92) 512MB 256-bit GDDR3 PCI Express 2.0 x16 HDCP Ready SLI Supported Video Card - Retail
Power supply: ?? thinking either PC Power & Cooling PPCT860 860W ATX12V / EPS12V Power Supply - Retail
or COOLER MASTER Real Power Pro RS-850-EMBA 850W ATX12V / EPS12V Power Supply 100 - 240 V CE, cUL, TUV, NEMKO, BSMI, FCC - Retail
CPU: Intel Core 2 Extreme QX9650 Yorkfield 3.0GHz LGA 775 130W Quad-Core Processor Model BX80569QX9650 - Retail
Heetsink: Thermalright XFI -14
RAM: (2) Crucial Ballistix 2GB (2 x 1GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Dual Channel Kit Desktop Memory Model BL2KIT12864AA804 - Retail
OS hard drive: Western Digital Raptor X WD1500AHFD 150GB 10000 RPM SATA 1.5Gb/s Hard Drive - OEM
Fans: Scythe SY1225SL12M 120mm "Slipstream" Case Fan - Retail
1 for heet sink 2 for side for case
and thinking artic silver cleaner and thermal compound
I want to go with the 8800 GTS & 4 1 gb RAM because will run in dual channel mode and because of cost and room to expand it later and I have not decided on os yet vista or xp and may get an after market VGA cools later as well
Thanks for any help or advice I can get
