Tom's Hardware > Forum > Graphic & Displays > Graphics Cards > 8800GT overclocking problems
Forum Graphic & Displays : Graphics Cards - 8800GT overclocking problems
Hey all. i have an 8800GT that just refuses to overclock. i've tried Rivatuner and AtiTool, but just getting nowhere! all i can do is adjust the fan speed. When i do overcolck the is no improvement and AtiTools doesnt even pick up my core or memory speeds.
please help!
Sponsored Links
oh, my System is:
AMD 5000+ @ 3.1ghz
Asus M3A Motherboard
600W Omega Megapower PSU
250gb Maxtor
20x LG DVD
Samsung 19" wide
2GB of DDR800
Reply to b_3d
what brand & model 8800gt? have you tried ntune as well? that is the official nvidia oc tool, although i use rivatuner myself.
------------------------------ AMD Phenom II X4 940 BE @3.5
Gigabyte 780g matx
G.Skill 4x2gig DDR2 800
evga 8800gt 512mb on 22" Gateway LCD
Reply to MayDay94
Its Chaintech, but really just a referance 8800gt with a sticker. Ntuner doesnt work either
Reply to b_3d
If it has the stock reference cooler you will need to get an aftermarket cooler to get any good OC's. I have the Zalman VF900 on mine with a steady idle temp of around 45 celsius and 58 under load.
Ive also heard you could use the VF1000 but i had no experience with how good it cool's.
------------------------------ http://valid.canardpc.com/cache/banner/495838.png
Phenom 2 940 @3.9ghz|Arctic Freezer 64 Pro|Vista 64 bit|GIGABYTE GA-MA790GP-DS4H |OCZ Platinum 4GB (2 x 2GB)DDR2-1066|Vision-Tec HD487
Reply to xx12amanxx
Some 8800GT's (and I say this from personal experience) just don't OC very well or at all so don't sweat it.
------------------------------ [:mousemonkey:1] http://img29.imageshack.us/img29/5041/vr2009champ.jpg
Reply to mousemonkey
I dont have a temperature problem. It just doesnt want to do anything at all.
Is there nothing i can do! Its the most expensive part im my entire PC. I want to brake tn 11 000 mark for 3DMark06
Reply to b_3d
Yep, there are some bad apples in those 8800gt. Bottom binned chips. It's rare, but some people out there will end up with them. That's the main reason overclockers tend to opt for the higher costing gts, aside from dual slot cooler.
------------------------------ Q6600@3.6ghz, GA-EX38-DS4 motherboard, 8gb 800mhz ddr2 4-3-3-12, 8800GTS(g92)@780mhz, 1TB + 1.5TB hdds, 850watt psu
Reply to dagger
*sigh* :-(
Thats just Great! Anyway, thanx for the input guys. I'll just have to make do with what i have untill next year.
Reply to b_3d
There are 774 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
