Tom's Hardware Forums » Homebuilt Systems » General Homebuilt » New System and I Need Some Advice
Word :   Username :
Bottom
Author
 Thread : New System and I Need Some Advice
Profile: stranger
More Information
Hello :).
I'm about to invest in a new comp from CyberPowerInc. since I hear that they are a decent custom system builder. I'm going to get this system:
600 watt PS
AMD Phenom X4 9500 Quad-Core
Asus M2N SLI nForce 560 Mobo
3 gig RAM
8800GT 512MB
500 gig HDD
Running XP
19' in monitor
I was wondering if I would be able to play a game like Oblivion or World in Conflict with all settings on max. I've had a crappy system for years and for once I want to be able to play a game at its best and not set for low settings. Do you all think I can?
Also: I am still deciding on a decent monitor and was wondering if oblivion will be in HD on a monitor like this:
http://www.newegg.com/Product/Prod [...] 6824254005
or how does that work?
Last One: Will most monitors like this be compatible with most comps? Do they all have one specification? Or are there different types that will work with certain setups?
Sorry I'm new to the pc gaming community :D
Thanks!
Related Product
The Ultimate in Alien Terror
Profile: journeyman
More Information
That system would be fine for almost any game these days. Crysis may struggle but that game struggles on anything. I personally would not buy an AMD system right now but thats a personal choice.
So generally yes you will be able to comfortably play most games with max settings smoothly.
As for the monitor, the one you have linked to I have never heard of the brand, but its native resolution is 1440x900.
HD is a silly term to use with PC games because technically they have been well over some HD resolutions for years. 720p is the lower of the HD formats and is 1280x720, your monitor has a native resolution of 1440x900 pixels.
ASRock Wolfdale 1333-D667 | E8400 'Wolfdale' @3GHz | Inno3D 8800GTOverclock 650/1900MHz | 2GB DDR-667 Corsair Value Select | Samsung 500GB HD | Silverstone ST56F 'Strider' 560w PSU | 3DMark06 - 12076
Profile: journeyman
More Information
Sorry I didn't answer your last question.
Any computer monitor will work with your pc. Just make sure to choose one that has been well reviewed from a reputable brand with a good warranty policy. At least 1 DVI input would be good too.
I'm sure some people here could recommend some good ones.
Profile: stranger
More Information
k thanks a lot man :)
I was wondering one more thing,when i do get a monitor with a dvi input, that would attach to the computer at the dvi input on the graphics card right?
Are intel systems better these days? I naturally went with AMD but if you think that intel might be better ill look into it! so is intel better?
Thanks ;)
jsc
Profile: old hand
More Information
GreatGreatWelcomSign wrote :
Are intel systems better these days? I naturally went with AMD ...
Why "naturally"? A few years back, AMD, in terms of performance, pretty much ruled the desktop. Currently, however, for sheer performance and overclockability, you cannot beat Intel systems.
Overclocking since 1978: TRS80, 1.77 MHz Z80 to 2.01 MHz.
Lord of the Duck Clan
Profile: Faithful Poster
More Information
While this review is from 2006, it still raises a few issues which you might want to consider carefully.
Quote :
The Bottom Line – 7.0/10
A score of 7 is considered “substandard,” and that’s exactly what we felt about this computer. We felt this computer was more than disappointing. Things went wrong in many different ways. We’ve evaluated computers that have scored in this range before, and they typically were good quality computers with one large and glaring exception that severely overwhelmed the rest of the computer’s ability to get stuff done. That’s not the case here. This is not a good computer with a terrible flaw – this is a below average computer across the board.
Dealing with a large, single, known issue is often better than dealing with multiple minor issues because one can prepare for the eventuality of having to deal with the problem, find ways to work around it, or even fix it and be done with it.
This is doubly true if you’re recommending a computer for a non-tech-savvy friend or family member. One phone call or visit home for a major issue is significantly less annoying than multiple calls with trivial – and easily preventable – issues. If I had bought this computer for my parents, I would have felt like tearing my hair out.
For this reason, we cannot recommend the CyberPower system for friends and family and advise any computer user to know exactly what they are getting into before they order a CyberPower system.
Full Review: http://consumer.hardocp.com/articl [...] 5zdW1lcg==
Let's see here.. Looks like your system is around $1700.
Look at Maingear. Around the same price, but excellent quality.
http://www.tomshardware.com/forum/ [...] ate-modode <-- Computer Builds
Success comes from knowing that you did your best to become the best that you are capable of becoming."-John Wooden
Sniper
Profile: Forum Fixture
More Information
@OP: Why not jump on the DIY train? :). You can easily build that PC for ~$800 if you DIY.
Message edited by Shadow703793 on 05-24-2008 at 12:56:17 AM
E2180 @3.2Ghz + P35DS3L +8400GS (700/475 OC)
http://farm4.static.flickr.com/3268/2588429538_b3c41b29c3.jpg
Google Ads
News
End nears for Mac version of IE
Published on December 19, 2005
Microsoft has advised Mac users of Internet Explorer (IE) to switch to rival browsers such as Apple's Safari. Read more
Microsoft takes OneCare security suite live
Published on May 31, 2006
Slightly ahead of schedule, Microsoft today released the final version of its first contender in the commercial security software segment: Windows Live OneCare includes a software bundle that promises to defend computers against common malware threats as well as free support for users that need advice in protecting their system or removing a virus. Read more
LAN Parties Get Advice, Coordination And Swag From Palit
Published on March 11, 2008
San Jose (CA) - Beginning LAN party organizers often struggle with mind-numbing business details, but that's about to change with Palit's launch of what it calls the "ultimate LAN party resource". Read more
Tclink demonstrates car-radiator based cooling system
Published on June 05, 2006
If regular computer cooling system aren't just enough, Tclink/Ebiz offers a liquid cooling system that uses an "automotive" radiator. Read more
Latest Reviews & Articles
Atom, Athlon, or Nano? Energy-Savers Compared
Published on October 03, 2008
We compared Intel’s Atom 230 and VIA’s Nano L2100 processors hoping to find the best product for low-power applications. VIA is in the vanguard of performance. Is this enough to beat Atom? Read more
Interview: Bigfoot's Killer NIC, Exposed
Published on October 02, 2008
Since its release, the Killer NIC has garnered a reputation for being an extravagant and largely unnecessary add-on for the do-it-yourselfer. Seeking additional insight, we approached the card's designer. Read more
Seagate's 1.5TB Barracuda: Bigger And Better?
Seagate is the first hard drive vendor to offer a 1.5 TB drive in the 3.5” form factor. Meanwhile, WD sent us its RAID Edition 3 (RE3) drive. We tell you which is the best HDD choice today. Read more
Updated CPU Charts 2008: AMD Versus Intel
Published on October 01, 2008
The processor is the heart of your PC, and our updated charts for Q3 2008 show 54 of them competing in terms of performance. Using our updated suite of benchmarks, compare your favorite AMD and Intel CPUs after reading this introduction. Read more
