Tom's Hardware > Forum > Homebuilt Systems > New System Build > budget system - help pick the parts please,
Forum Homebuilt Systems : New System Build - budget system - help pick the parts please,
Hey folks,
I know there's a lot of these kind of posts, but I am in urgent need of ya'lls help to spec out a budget system. The system is for a friend and his wife who'd Dell Dimension 2400 just went out on them.
We will be scavenging as much as we possibly can from the dell system: monitor, keyboard, mouse, hard drive, etc...
would need:
case, MB, ram, vid card, power supply, cd burner, CPU, *whatever else I can't think of, like thermal compound*
Computer will be used for: simple internet surfing, digital camera photos, emailing.... Budget: eh, $500 or less (if possible)
thanks in advance to anyone who takes the time to reply, it is greatly appreciated.
Sponsored Links
CPU: Intel E2160: $70
Motherboard: Gigabyte GA-P35-DS3L : $85
RAM: 2GB DDR2 800 Crucial Ballastix : $30
GPU: 8600 GTS: $90
DVD RW: SAMSUNG Black 20X DVD burner: $30
PSU: Corsair 550vx : $65
[b]Case[b]: Antec/Coolermaster: $55
Total: $425
That would serve you very well. And you'd save $75 from the budget.
This case comes with a 380W power supply... you'd save more $$ that way.
http://www.newegg.com/Product/Prod [...] 6811129032
------------------------------ Intel E6750 * Gigabyte GA-P35-DS3L * Galaxy 8800GT 512mb 620MHz* Corsair VX450 * 2GB Transcend 667* 2x120GB Seagate SATA * Altec Lansing ATP3*
Reply to mihirkula
GPU: get the ASUS EN8600GT SILENT, no fan, I'm sure she will appreciate it.
Reply to Vdrummer
- 0 +
There's no need to spend $90 on a video card, I'm guessing there will be very little to no gaming done. A motherboard with AMD's new 780G chipset should be more than sufficient (integrated 8 channel audio + radeon HD 3200 with DX10 support)
I'd recommend the following parts:
Case: COOLER MASTER Elite RC-330-KKR1 55 + 350W PSU $55
http://www.newegg.com/Product/Prod [...] 6811119118
MB: GIGABYTE GA-MA78GM-S2H AM2+ $90
http://www.newegg.com/Product/Prod [...] 6813128090
CPU: AMD Athlon 64 X2 5000+ Black Edition $88
http://www.newegg.com/Product/Prod [...] 6819103194
RAM: Crucial Ballistix 2GB DDR 800 $35
http://www.newegg.com/Product/Prod [...] 6820146565
Media
: Pioneer Black 20X DVD+R 8X DVD+RW $30
http://www.newegg.com/Product/Prod [...] 6827129018
Total: $298
Talk about bang for the buck ;)
Good luck.
Reply to Dior
There are 1356 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
