I've got about £350 to spend on a new build. Doesn't need to be anything spectacular (obviously for that budget), just needed for general work, t'internet browsing and an occasional bit of gaming (COD and Pro Evo).
The spec I've got there is slightly more than i wanted to spend.
Do you think i need the 620W PSU for this build or would the Cosair HX 520W be good enough???
Is the graphics card good enough for a reasonable standard of gaming?
If it is good enough, for a similar price would i be better going for the Nvidia 8600 GT???
Is there much difference in performance of the Gigabyte GA-P35-DS3R mobo (listed) compared with the cheaper Gigabyte GA-P35-DS3L?
Hi there...that 620W PSU is quite overkill for a single GPU setup... you can save a lot of cash by getting the 520HX or 550VX (its generally cheaper than the 520hx).
Also you can save more cash by going for a non-RAID mobo, i.e. P35-DS3L. If you're serious about RAID, then the DS3R is a good choice.
You could use the saved $$ for a bigger HD or so.
Also get the aftermarket Arctic cooler only if you're thinking of overclocking...otherwise the stock cooler is just fine.
Message edited by mihirkula on 05-23-2008 at 09:07:02 PM
