P pmx9us Honorable Nov 23, 2012 4 0 10,510 Nov 23, 2012 #1 on boot up it says" floppy diskette seek failure strike the f1 key to continue, f2 to run the setup utility"
ex_bubblehead Titan Moderator Aug 24, 2012 16,247 1,516 87,240 Nov 23, 2012 #2 If you don't have a floppy drive then go into BIOS and disable the floppy device. Upvote 0 Downvote
P pmx9us Honorable Nov 23, 2012 4 0 10,510 Nov 23, 2012 #3 went to boot sequence and tried to delete and it said i can not delete this item. according to the sequence the only two things that are bootable is the onboard sata hard drive and the onboard or usb cd-rom drive. Upvote 0 Downvote
ex_bubblehead Titan Moderator Aug 24, 2012 16,247 1,516 87,240 Nov 23, 2012 #4 You don't disable it there. Enter the BIOS setup (refer to your documentation), locate the selection for Floppy Disk and disable it. Upvote 0 Downvote
P pmx9us Honorable Nov 23, 2012 4 0 10,510 Nov 23, 2012 #5 then after leaving the setup it says now" no boot device available strike f1 to retry boot, f2 for setup utility" Upvote 0 Downvote
ex_bubblehead Titan Moderator Aug 24, 2012 16,247 1,516 87,240 Nov 23, 2012 #6 That means that you've also disabled the HD boot or have a failed hard drive. Upvote 0 Downvote
P pmx9us Honorable Nov 23, 2012 4 0 10,510 Nov 23, 2012 #7 when i try to enter bios it just freezes up and says entering setup and goes no further. i think you maybe right about the failed hd. Upvote 0 Downvote
