Tom's Hardware Forums » CPU & Components » CPUs » CPU upgrade problem
CPU upgrade problem
Add a reply
 Word :   Username :
Bottom
Author
 Thread : CPU upgrade problem
Profile: stranger
More Information
I recently bought the http://www.newegg.com/Product/Produc...82E16819103211 to upgrade from my AMD Athlon 64 3200+. After installing it, nothing happens when i turn on the computer. The lights on the motherboard turn on but when i press the power button it doesnt start up. I checked my motherboard and stuff before hand and my motherboards socket is AM2 so that shouldnt be the problem. I'm not sure what model motherboard it is since it's a Dell and it doesnt show what it is in CPU z. Anybody have any ideas?
Related Pr oduct
Profile: old hand
More Information
Sorry, the link is broken at present. What is the CPU you have purchased? Did you check with Dell what you can upgrade to? If new PSU uses more power, PSU may not be good enough. Are you OK if replace original CPU?, If so, is DOA CPU or PSU issue.
Mike.
caffeine boosted
Profile: addict
More Information
Put in the old cpu, update your bios, then install the new cpu
Profile: addict
More Information
This is the wrong place to ask about proprietary MB.
You need to go to Dell Support:
http://support.dell.com/support/do [...] gen&~ck=gp
You don't need the MB model number. Just search by model, tag, etc. Try to find a newer BIOS for your Dell model that supports the ??? (why post a nonworking link ??? - just tell us the CPU!!) AM2 processor you have bought.
You need to post here if you can't find a suitable BIOS update:
http://www.dellcommunity.com/suppo [...] d=dim_bios
You won't find many people using Dell desktops on these forums...
Also you are unlikely to get help if you can't even tell us the Dell model!! :lol: :lol: :lol:
Bob
LVL: ????
Profile: old hand
More Information
Add a reply
Google Ads
