Tom's Hardware > Forum > Storage > General Storage > Need 4 Speed: laptop 7200 VS esata
Forum Storage : General Storage - Need 4 Speed: laptop 7200 VS esata
Hi, I'd love to be enlightened about performance.
What's best between a 2.5" internal laptop hdd running at 7200rpm versus a 3.5" external SATA drive running via eSata?
Basically I want to buy a laptop for video editing and motion graphics, but not sure I should get one with the faster internal hdd or if it's not worth the extra cash.
Any tips on that much appreciated...
Sponsored Links
While most laptop hard drives are slower than their desktop counterparts, using a eSata boot drive is not a good idea.
Doing so will not only require you to lug around another piece of hardware, you will also be limited to working tethered to the wall (an eSata enclosure requires an external power source).
If you really need a fast laptop, replace the stock hard drive with a non-JMicron SSD or Raptor (if it will fit, the 2.5" raptors are quite thick).
A non-JMicron SSD, while expensive, would be your best option and, if you can afford it, well worth the extra cash.
------------------------------ If the automobile had followed the same development cycle as the computer, a Rolls-Royce today would cost $100, get a million miles to the gallon, and explode once a year, killing everyone inside.
PSA
Reply to outlw6669
Interesting, the Raptor seems fast and is not too pricey. SSD is over budget...
But I don't really care about mobility, it's going to be a workstation that won't travel much. So my first concern is performance, basically what's the best solution to edit videos and do some 3D on a PC laptop using Premiere and After Effects. For around 1000 euros or pounds. And knock out some songs with my guitar :)
Reply to paramita
As the 2.5" Raptor is the fastest conventional hard drive for both laptops and desktops it would be your best non SSD option.
Do not give up on SSD's right out of the gate, though.
I am not sure about the prices in your area but you can probably locate a 60-120Gb Intel X25-M or OCZ Vertex SSD for about the same price as a 300Gb 2.5" Raptor.
If you do not need a massive internal drive, or you plan on using external storage, a SSD will defiantly outperform the Raptor and, as it will not be as thick, there is a better chance it will fit in your laptop.
Message edited by outlw6669 on 08-31-2009 at 03:16:28 PM
PSA
Reply to outlw6669
The 2.5" Velociraptor will NOT run in a laptop. It may be a 2.5" drive, but it requires a 12V power feed. Notebook drives are designed to run off a 5V and 3.3V only, without the 12V, so notebooks do not supply drives with a 12V (the pins are the same as on desktop drives, but the 12V pins just aren't connected).
------------------------------ Asus P6T deluxe
i7 965 @ 4.2GHz (200*21), 1.384V
12GB Corsair Dominator DDR3-1600 CAS 7
Reply to cjl
:ouch: :o :whistle:
I had not heard about that before now.
Yup, looks like the Raptor is taller, has offset power/sata plugs and requires 12v power.
Defiantly will not work in a laptop.
Sorry about that...
PSA
Reply to outlw6669
There are 1230 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
