Tom's Hardware > Forum > CPU & Components > CPUs > i my system having throttle issues? low volt? pics posted please help.
Forum CPU & Components : CPUs - i my system having throttle issues? low volt? pics posted please help.
My system is a week old and i was having random reboot issues. first it was doing a bsod and the error i was getting was telling me a bad install of windows. i was running xp 64 no im on xp pro. was running a msi 8800gts and the video was getting worse so after i changed cards things worked great 2 days in i get my first reboot. running the 8.6 drivers atm
specs are
q6600
ddr800 gskill 4gig
ati hd 4850
msi p45 neo-f
here are some screen shots of my system at idol
http://i45.photobucket.com/albums/f68/psychotikcow/taskmanager.jpg
http://i45.photobucket.com/albums/f68/psychotikcow/temps.jpg
http://i45.photobucket.com/albums/f68/psychotikcow/memory.jpg
http://i45.photobucket.com/albums/f68/psychotikcow/throttle.jpg
http://i45.photobucket.com/albums/f68/psychotikcow/cpuinfo.jpg
let me know if you need any more info ..
Message edited by psychotikcow on 07-03-2008 at 07:55:04 AM
Sponsored Links
What PSU do you have?
Reply to liljone
ocz 600w stealth stream
Reply to psychotikcow
- 0 +
Your RAM is DDR3 right? If so 400mhz frequency would result in 1600mhz total from each chip. Very few systems can do 1600mhz at 5-5-5-15 timings, so that could be your problem.
However, just to cover my ass, my system always reports DD3 RAM even though its actually using DDR2 so yours could be doing the same.
Reply to JDocs
yah its ddr2 looking at the box right now ddr2-800 pc2-6400 2048mb x 2
the timing is suppose to be 4-4-4-12 but locked up on those settings when i tried its on auto right now
Message edited by psychotikcow on 07-03-2008 at 08:48:41 AM
- 0 +
What is your RAM voltage? If it is defaulted at 1.8v, you may need to bump it a little, maybe to 2.0 or 2.1.
------------------------------ There is ALWAYS a drone. Exactly where, or how many drones you will encounter may vary, but that there will be at least one will not.
Reply to jtt283
i have it set at 2.1v was at 2.0 just switched to 2.1 so far stable
Does it reboot at idle or when using a program?
Reply to blackwidow_rsa
it was rebooting under both before after some changes rebooted while gaming
There are 1089 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
