Go to Nvidia web site download, and save to desk top, driver for Vista.
From control panel uninstall ALL video card drivers. Reboot
Install from desk top saved driver. Reboot and run 3dmark06 (no AA)
Keep in mind the settings for 3dmark, higher resolution or any other aa settings will severely cripple the score. The "common" benchmarks are based on default settings.
Also yes, make sure you get the most recent drivers for your motherboard and video card.
If none of those help, try another benchmark, like 3dmark 05 or 03 see if you get the same results.
Usually grahpics have issues other then just slow performance if there is somethign wrong with the card itself. Like display corruption or system instability while playing games.
------------------------------A+ Certified 220-601 and 602
Antec Nine Hundred Gaming case/Core I7 920/Asus P6TSE/EVGA GTX 260/4GB OCZ 1600/Win 7 64bit
Reply to cranbers
I uninstalled the driver and restarted. Reinstalled the latest driver from nvidia website. No luck - still running at 2-4fps. (aa off) all settings at default
There are some settings in bios - but even on the standard settings this should be doing something good.
