After installed vista have to use the power switch to turn the pc on
Last response: in Windows Vista
Related ressources
- Do Not Turn Off Or Switch Power - Forum
- PC Only powering up by PSU Switch , but turns off after a few Seconds - Forum
- Computer will not turn on/ power up after crash during light use . - Forum
- New build shutting down after 3 minutes & power switch problem - Forum
- PC only showing 2.99gb RAM out of 16gb after fresh Windows Vista install. - Forum
Related ressources:
- ForumPower supply won't turn on after pressing the power button on PC
- ForumHELP!Shut down comp then flipped switch on power supply, won't turn on
- ForumAntec 900 power button doesn't always turn on PC
- ForumPC turns on minutes after pressing the on switch
- ForumShould A Laptop Turn On/Attempt To Power Up If The Hard Drive Is Dead?
- ForumMy computer wont turn on after i installed a new graphics card
- Forum[Solved]Can't turn computer on after power outage
- ForumComputer will not turn on after power surge
- ForumVista Black Screen after installing IDE HDD
- ForumPower Button Does Not Turn Machine Off? Turns on Though
- Forum[Solved] Vista busness 32 product key free
- ForumReinstalling / Upgrading Windows Vista Ultimate with VLK
- ForumFree toshiba recovery cd download Vista A205S5843
- ForumAdobe flash player wont download on vista 32 bit
- ForumDxdiag says have directx 11 but intel graphics card says 10 0
- More resources
Read discussions in other Windows Vista categories
