Sign-in / Sign-up
Solved
[ /NOEXECUTE=OPTIN + PXE-media test failure problem
  • Computers
  • Hard Drives
  • Windows Vista
Last response: in Windows Vista
November 29, 2012 6:05:40 PM
Hello,
Every time I start my computer, it loads up past the motherboard screen then stops in a black screen. The black screen shows the following:
for Windows vista
Path:\Windows\System32\Winload.exe
Partition 1
Hard Disk e171e171
[ /NOEXECUTE=OPTIN ]
Press Enter To Submit
After pressing enter my computer boots than page with (safemode. dtart normally apper) and some thing repeat on vista don't load
it all sarted when i boot my hard disk in another pc ( it was working fine there) and when i kepe it in my pc i started showing this problem
plz if any one have idea plz help
More about : noexecute optin pxe media test failure problem
Best solution
November 29, 2012 6:13:11 PM
msko1147 said:
Hello,
for Windows vista
Partition 1
Hard Disk e171e171
What does this mean ?
If you installed Windows on this disk in another PC, it won't work on yours.
November 29, 2012 6:21:02 PM
Best answer selected by msko1147.
m
-1
l
November 18, 2015 8:29:22 PM
ksiemb said:
msko1147 said:
Hello,
for Windows vista
Partition 1
Hard Disk e171e171
m
l
