2x EK-Multioption RES 400 Rev. 2
- Fitting Size 1/2" Barb for 1/2" ID tube
- Reservoir Accessory Add EK-ANTI-Cyclon
2x Feser One F1 Cooling Fluid - Clear/UV Blue - 1 Liter
12xScythe S-Flex 120mm Fan - Ultra High Speed (SFF21G) (i know i need only 6 but i will get 6 more in case any of them stopped working so that i can replace it quickly)
here is a link to the pump http://www.performance-pcs.com/cat [...] eb376034de and i may post some pics for the build when i buy the water cooling parts and set them up,because i am sure it will look better with the watercooling
koolance pmp-400 (ddc3.25) with xspc restop (or ek x-top v2) = best flow and head
pump
[url=http://www.performance-pcs.com/catalog/index.php?main_page=product_info&cPath=201&products_id=22586&zenid=78041990f3b2418edcbf48eb376034de][/url]
top
[url=http://www.performance-pcs.com/catalog/index.php?main_page=product_info&cPath=439&products_id=23357&zenid=78041990f3b2418edcbf48eb376034de][/url]
or you can get this top and stick 2 pumps on it for extra flow
the eheim pump is indeed powerful, but its an AC pump so you need an extra power source for it. It is also much larger than the lang ddc pumps making it harder to work with, and if op is going for two loops, its not really an easy pump to work with.
@op, if its your first build the lang ddc pumps w/ a top is probably the easiest to work with.
sounds like that your computer will be a beast, the SkullTrail MOBO would have been a good option with that kind of Budget. Anyway.
Hi guys I'm looking to set up a water cooling system for my AMD6000+ I have allready purchased a Thermaltake AquaBay M3 1U Liquid/Water Tank, and am now looking for a Radiator. I wish for a good one because i will be upgrading my system to the AMD Bulldozer when it is released. i would like to use my watecooling for my new computer,
With my current system i will be cooling a AMD 6000+ CPU & Nvidia Geforce 9600 512mb, The Graphics Card is overclocked, but because i'm cheap i have a MOBO that doesn't allow me to overclock my cpu.
Are there any reviews on this radiator, http://www.koolance.com/water-cool [...] uct_id=634
I am after a radiator of this type or size.
Or does any one know of any other good radiators, also i am after a shop in Melbourne Australia that sells Water cooling gear.
Thankyou
Bernie
Message edited by berniemansell on 03-30-2009 at 06:01:45 AM
computersss if you have the cash have you considered a custom phase change? you might be interested if you look into them go to extremesystems.org for more info
THANKYOU Conumdrum
The cool-z.com.au web site has helped me out. I can get most of my water cooling needs. i am thinking about getting the Swiftech MCR320 Quiet Power Radiator (3x120) Info on this product can be found here
http://www.sidewindercomputers.com/swmcqupo3xbl.html I'm hoping that this radiator will be ok.
Another question?
are there any differences between Gold, Copper, or Pure Aluminium, water Blocks.
I'm guessing that Copper would be the best option.
^Get the copper blocks. Don't bother with any thing else except Silver(if you got the money,lol). Gold (which is usually used to counteract corrosion) actually has less thermal conductivity than Copper. Aluminum is not as good as copper but usually cheaper. Be warned, don't mix Copper + Aluminum (Galvanic corrosion).
