Tom's Hardware > Forum > CPU & Components > Power Supplies, PC Cases & Case Mods > case needed with good cable management and space for water cooling
Forum CPU & Components : Power Supplies, PC Cases & Case Mods - case needed with good cable management and space for water cooling
Hi all,
i am looking for a a good case with good cable management and space for water cooling later on. i stupidly got a jeantech case from PC WORLD because it looked good, once home realised it had sharp edges to cut both me and cables, poor airflow even with numorus fans and genral poor build quality.
well as i said i am looking for new one now with good cable management and the posibility of water cooling later on.
Any help would be greatly appreciated
Sponsored Links
What's your budget?
Reply to galta
no more than £150, this time i want to spend a bit more and get the right one
Reply to mlj
So you live in UK...
I'm not famliar with prices there, but assuming 2US$/£ and newegg prices, my suggestions are:
1 - http://www.newegg.com/Product/Prod [...] 6811163073
This is the most expensive, but the best. Big, full of features and ready for WC. In the US it costs $299. There used to be a model with no transparent side panel (who needs it?) where you could save some $20. If you find it, go for it.
2 - http://www.newegg.com/Product/Prod [...] 6811119150
Also very good, and also cheaper. $229 after rebate, great cable management and ready wor WC as well.
Reply to galta
thanx these cases look good, think i'll go with the coolermaster as its ready to go
Reply to mlj
oops sorry i ment the silvertone
Reply to mlj
could anyone tell me if the Antec 1200 or Thermaltake Armor would be a good buy before i get the silverstone
Reply to mlj
Gigabyte 3D aurora 570.
Loads of space, good cooling, water cooling ready, excelent cable management
Reply to panicatak
the best one i've found is the NZXT Khaos
Reply to Aurora18
I don't do any water cooling, but I can say though that the Thermaltake Armor is a pretty big case. I have one for my current rig and I have not had any space issues. I am sure you could set up a comprehensive water cooling system with it.
------------------------------ Take my love, take my land, take me where I cannot stand.
I don't care, I'm still free you can't take the sky from me.
Reply to njalterio
One possible solution, albeit not the best ( http://www.newegg.com/Product/Prod [...] 6811129025 )
It's a shame that NewEgg has so many cases in the $100-$200US range but almost all don't meet your needs (H20 cooling) or are hideous/cheap-looking.
------------------------------ 17" MacBook Pro: 2.66Ghz, 4GB DDR3-1066, 256GB Corsair P256 SSD
Reply to halcyon
I would suggest this one:
http://www.newegg.com/Product/Prod [...] 6811146047
it's already set up to have a watercooling system inside
------------------------------ It is a very newb question, which is why I ask it.
Reply to jonyb222
I also have the Thermaltake Armor. It is huge. It has lots of space. The PSU was a real pain to get in though. It looks like they have slightly redesigned them though and it seems to be better. I am running an external water cooling on mine using a Reserator XT and using the pre made holes for the tubes. I love the air filters on the front as My office is also the laundry room and that lint plays havoc. I removed the big fan from the side panel of the armor and close it up so that the only air would come in through the front vents which have the filters. I love the small drawer in it also is it holds my screws and stuff. It holds E-ATX MB's so it works for the XEON motherboards.
Probably the only thing I can really complain about it the tigh fitting psu chamber mine has and there is no cable management. It is also HEAVY.
------------------------------ Turas
ASUS P6T MB, Zalman GS1000, Core i7 920, 12GB Ram, ATI 3870, 27" LCD, Adaptec 51645 SAS RAID, 4 -10K 2.5 SAS Seagate drives, ARECA 1680ix w/4GB Cache, 4xWD VR HD Drives, 8xOCZ Value 60GB SSD
Reply to Turas
I am using the Antec P-180 case, with 2x 120 mm rads IN the case, pump in the bottom, bay res, and it is whisper quiet.
Fairly cheap too, around $100-120 US.
Added a third 120 rad to the top to cool my Q9450, and 2x 8800 GTX's. Cpu stays mid 40's load, and gpu's stay mid 50's.
Reply to Granite3
I am running a Gigabyte Aurora with WC. The 2x120 mounts directly to the back of the 2x120's. I recently added a big passive radiator to the side as well. It's pretty big inside, and there is room for a bay res and pump as long as you don't run SLI or Crossfire....or get one of those little pumps. I cut out my HDD bays to mount my pump there...and put my drives in a bay cooler mount.
------------------------------ The Pastafarian belief of heaven stresses that it contains beer volcanoes and a stripper factory. Hell is oddly similar, except that the beer is stale, and the strippers have VD
Reply to rubix_1011
thanx for every bodys help on this, befor i go and buy one of them is there anyone with a Antec 1200 and can tell me how much room there is between the mobo tray and side of the case
Reply to mlj
^ Yeah, good call. I have been curious about the 1200 since they came out. Would be nice to see a good comparison on the 900 vs 1200. Any links to reviews??
Reply to rubix_1011
if i get a Antec p-182, updated version of the p-180, i think i could mount 2 120mm radiators at the back and top, right? providing i am right so far would this cool the coolent well enoughf to cool my rig.
Q9450
9600 GSO
VRMS's
NB and SB
plus anythink else you recomend cooling
thanx
Reply to mlj
Check this one
LianLi PC-A70 Case
Spacious, ready for water cooling and lot of fans
------------------------------ LianLi PC-A70 Case/Enermaqx Galaxy 1000W/Asus Rampage Formula/E8500/Thermalright Ultra 120 Extreme Lapped/Scythe S-Flex SFF21F/Crucial Ballistic Red Line DDR2800 PC6400(2X2)GB/8800GTS 512MB/WD Raptor2X150GB/ViewSonic VX922(1280X1024Max)
Reply to kad
kad wrote :
Check this one
LianLi PC-A70 Case
I use the Lian-Li A70 myself, great case, lots of room. However, it is expensive. It like someone saying "Can you recommend me a good car?" and us replying "Yes, get a Mercedes E400".
Reply to halcyon
thanx for all your help, i have decided to with Antec p-182 as i really like the look of it and has space for 3 120x120mm radiators.
Reply to mlj
There are 1142 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
