Tom's Hardware > Forum > Storage > Hard Disks > Odd problem
Odd problem
Forum Storage : Hard Disks - Odd problem
I have a Seagate ES.2, 250gb HDD, it was used as a storage drive in Windows XP. I have removed it from my old build a while ago, and have hooked it up via USB adapter in Windows 7. It comes up as a working drive in Device manager but not in Explorer, My Computer, or even in Disk Management.
Since it doesn't even show up in Device Manager I can't assigna drive letter, I have restarted the pc, updated drivers, etc etc etc. Nothing I've tried seems to work so far, any ideas?
Sponsored Links
It's probably an issue with your motherboard's USB drivers. Have you made sure your computer is updated in this regard?
------------------------------ Desktop | E7300 | P5KPL-AM | 2GB DDR2 667MHz | NVIDIA 9500 GT | ST3320613AS | w2228h
XPS M1330 | T8300 | Dell 0U8042 | 2GB DDR2 800MHz | NVIDIA 8400M GS | WD2500BEVS-75US | 1280 x 800
Reply to r_manic
I checked that too, it's weird because other USB devices will work fine like flashdrives, headphones, cell and so on.
I also have the same issue with a 2.5" external I've used over the years as an odds and ends storage drive. I'm wondering if Windows 7 maybe cannot see Fat32 o rNTFS on the other drives b/c they were formatted on xp machines?
Reply to FrozenGpu
When I had the same problem, I downloaded a liveCD of Gparted partioning software, burned it, and booted the system from the live CD with the "new" hard drive attached to the system via a usb caddy. I then formatted this drive with NTFS, then rebooted the system into Windows. The hard drive was recognized right away. Hope this helps :p
Reply to foxy_roxy
But If I reformat with NTFS doesn't that mean it will wipe away all data on the drive?
Reply to FrozenGpu
Well obviously reformatting will wipe all data, anybody have any ideas that wouldn't require reformatting the drive?
Reply to FrozenGpu
If you can get your hands on the Virtual Windows XP program, it emulates XP within a window. However, due to my limited use of it, I'm am not sure if it simply accesses the drivers which 7 runs from; (Fairly certain it has some independent drive functions).
Reply to Viking_AM
There are 1218 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
