hello first time building a system.. please critize and tell me whatever u think its bad!
NEXA BLACKLINE ATX MID CASE
Q6600 CORE 2 QUAD 2.4GHz G0
CORSAIR 520W v2.2
ABIT IP35 PRO LGA 775 INTEL P35 ATX
nVIDIA GeForce 8600 GT 255MB 128-BIT PCI
CORSAIR 4GB (2X2GB) 240 PIN DDR2 SDRAM
CREATIVE SOUND BLASTER AUDITY SE 7.1
WINDOWS VISTA HOME PREMIUM 64BIT
SOME Q`S
1. What do you guys think about the graphic card?
2. Will my system be able to run VISTA? sure i am but just want to make sure.
3. Should i go with the 32 or 64bit for vista?
4. Do you thinks think i should get a CPU coolin or would the one it comes with be alright?
5. How much OC would i be able to reach?
Thanks!
CORSAIR 520W v2.2
SOME Q`S
Thanks!
