This is what the internals will be : Q9450 with a Zalman 9700NT Asus P5E Deluxe Corsair TX750W 4870 in crossfire or a 4870x2 when it comes out Only running one HD and Optical Drive
I have always leaned towards Antec, especially the p182/nine hundred...but it lacks a removeable motherboard tray which would make installation a breeze.
Here are the things I'm looking for in this case: -Removeable mobo tray as mentioned -Massive air flow for overclocking/great cooling, preferably 120mm+fans -Cool and Quiet -Tool-less assembly would be nice. -Ample space for Zalman 9700NT+crossfired GPU/big GPU -Cable management system if available -Easy installation!!!!
Thank you for your time!
Message edited by adreen on 07-09-2008 at 03:01:02 AM
from what i've heard, the Antec 900 is your best bet, or possibly the NZXT Tempest, which is basically the same thing. antec also now has the 1200, which is an improved version of the 900.
actually that post was in response to the antec 1200 suggestion kinda responded to both posts at once actually. thanks for the links.
is the nzxt tempest really that amazing? or is there a refresh model with removable mobo tray?
