Tom's Hardware Forums » CPU & Components » Power Supplies, PC Cases & Case Mods » about the power supply requirement
Add a reply
 Word :   Username :
Bottom
Author
 Thread : about the power supply requirement
Profile: stranger
More Information
is 500w enough for this computer
intel e8400 3ghz
2gig ddr2 kingston 667mhz
one 120gig hard drive 7200rpm
one 80gig hard drive 7200rpm
asus 8800gt 512mb
motherboard: asus p5k-vm
case: antec 3 hundred
Related Pr oduct
Profile: enthusiast
More Information
IF it's a quality PSU. AMPS, not watts is what matters.
Read here for a while:
http://www.jonnyguru.com/
Your GPU card etc needs xxx amps as does other stuff................. What does the card need?
500w is usually enuff if it's a decent PSU.
Message edited by Conumdrum on 07-09-2008 at 05:12:50 AM
I went water!:clap:
Abit AW9D Max I975X/ICH7R
E6600 3.28Ghz 2 Gig OCZ
CPU WB Fuzion unbowed (20C/37C)
Profile: Ancient Poster
More Information
It's enough, even if it's not a "decent psu." :p
500w gives enough headroom to cover that setup.
Q6600@3.6ghz, GA-EX38-DS4 X38 chipset motherboard, 8gb 800mhz ddr2 4-3-3-12, 8800GTS(g92)@780mhz, 1TB 7200rpm 32mb cache hdd, 850watt 12v rails=4x20amp powersupply
Profile: stranger
More Information
Profile: addict
More Information
If it isn't quality, 500W is not enough. JonnyGuru did a roundup of bargain bin power supplies, and they had a cheap PSU that said it was rated for 650W die at 184W of load. Most died before rated load, and getting near that point had voltage ripple way outside of ATX specifications.
Can you give us the exact model of the power supply?
Edit: beat me to posting, the Earthwatts are a great line of PSUs, cheap, SeaSonic built and high-efficiency, it will have no problem with your setup.
Message edited by gravemind1 23 on 07-09-2008 at 05:27:43 AM
Profile: nimble knuckle
More Information
that psu will be fine.
Profile: stranger
More Information
ok
thx for the help guys :)
Add a reply
Google Ads
