Tom's Hardware > Forum > Motherboards & Memory > General Motherboard > Help Selecting Replacement Motherboard for Athon X2 4200+ Socket 939
Forum Motherboards & Memory : General Motherboard - Help Selecting Replacement Motherboard for Athon X2 4200+ Socket 939
I have a MSI K8N Neo4 motherboard that is acting up and I need a replacement. I am getting blue screen reboots which I suspect is from the SATA RAID controller. I am already using the 2nd SATA controller because the 1st got buggy about a year ago. The MB has two SATA RAID controllers onboard.
I can't find any retail socket 939 motherboards available from my normal sources. I really don't want to trash a system that gives me all the speed I need: Athon X2 4200+ Socket 939, 2 GB of Corsair DDR400, WD 74GB Raptor for operating system & programs; plus other drives for the data.
Does anyone have any replacement/upgrade options to suggest?
Thanks,
Allen
Sponsored Links
------------------------------ E8500,GA-EP45-UD3R, 8 GIG MUSHKIN, XFX 4890 , ASUS 22", WD 640 X 2, CM 532, CM 650TX
Reply to royalcrown
Also check computer geeks. They usually have 2-4 939 boards in stock.
Reply to o1die
Thanks for your help.
Allen
Reply to allen_car
There are 1247 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
