Tom's Hardware > Forum > CPU & Components > Power Supplies, PC Cases & Case Mods > Need help! what computer case to take? Antec VS CM VS TT
Forum CPU & Components : Power Supplies, PC Cases & Case Mods - Need help! what computer case to take? Antec VS CM VS TT
Hey!
I'm about to buy my new computer, and i have a slight problem
The Ultra 120 Extreme air cooling i choose, does not fit into the "Thermaltake Armor Plus MX Aluminum Silver"
If I want to use the cooling with that case, i have to remove the fan on the window
people tell me that if I do, it not going to be effective.
So basically my choices are -
1. Thermaltake Armor Plus MX Aluminum Silver - without the fan on the side window
2. CM 690
3. Antec 900
4. Antec P182
This is the computer I'm about to buy
INTEL CORE 2 DUO S775 3.0GHz E8400 45nm : " SLAPL" - BOX
ASUS MAXIMUS FORMULA
SAPPHIRE PCI-EX 2.0 RADEON HD4870 512MB GDDR5 - RETAIL
SEAGATE BARRACUDA 7200.11 500GB 32MB SATA2 NCQ - ST3500320AS
SAMSUNG SH-S223B x20 SATA
OCZ 2048MB (1024MBX2) DDR2 800 CL 4-4-4-15 - REAPER HPC : OCZ2RPR8002GK
CORSAIR 650W TX : CMPSU-650TX
THERMALRIGHT ULTRA 120 EXTREME
SCYTHE S-FLEX 120mm SFF21E
What case should I take??
Sponsored Links
Go for the NZXT Tempest, it's similar to the 900 with same price but it already has all it's fans on it
http://www.tomshardware.com/review [...] 951-3.html
------------------------------ It is a very newb question, which is why I ask it.
Reply to jonyb222
- 0 +
The main problem is if I take it, then I will have to wait alot of time to get it
Reply to Moti
^^ for the tempest or for every case other than the armor plus?
Reply to jonyb222
- 0 +
Only for the Tempest
In fact, the computer is already built on the Antec 900
I can take it tomorrow, but I'm not sure what case should i take :(
Reply to Moti
- 0 +
Ive had both the CM-690 and the p182.
The CM-690 was a dream come true compared to the p182. Cant speak for the 900 though.
Reply to skittle
- 0 +
Well, from what i can tell, the C690 is right in the middle
Both Antec 900 & Antec P182 have a lot of advantages and disadvantages
The CM690 seems to be right in the middle, most balanced one
Reply to Moti
- 0 +
i don't think u can go wrong with any of those. those are actually 3 that i am considering myself along with the tempest.
if u want something low key, but very very quiet and ample fans, p182 is great. two of my friends have them, comps are whisper quiet with the extra thick walls. it's no slouch coolingwise either, with 3 standard 120mm fans, and an additional 2 optional 120mm.
something more flashy, and massive massive air flow, go for the tempest/900. both of those can really push air.
cm690 is the solid performer of the bunch. cheapest too. if you're not big on cases, and rather put the extra 20-50 bucks somewhere else, do it. has plenty of large 120mm fans to keep your parts frosty.
all personal preference, you're not going get royally screwed either way. they're all great cases
Message edited by adreen on 07-09-2008 at 09:31:08 PM
Reply to adreen
- 0 +
Basically what I've heard from people is - don't take the Antec 900
They say it like a vacuum cleaner, and makes noise like a ballistic missile
Someone suggested to take the Armor +MX with Zalman 9500, and give up the Ultra 120 Extreme
Is that a good choice?
Reply to Moti
There are 1270 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
