Yes No
Ads
Tom's Hardware > Forum > Storage > Hard Drives > X25-e / adaptec 5805 /raid0 throughput problem
Forum Storage : Hard Drives X25-e / adaptec 5805 /raid0 throughput problem
For my application (data acquisition) I need stream as fast as possible to disk
Inspired by the posted 2.2GB/s results posted in Tom's hardware, I set up a RAID0-array using 8x Intels X25-E ssd drive (32GB) and an adaptec 5805 RAID controller, hoping to achieve about half the speed (1.1GB/s) when using half the number of drives (8 vs. 16). Even though I need the storage for sequential writing I went with SSD technology for lower power consumption / no cooling issues.
Unfortunately the sequential writing throughput is by far lower than expected. When streaming to a single disk, I get an average of 196 MB/s writing speed, with a short peak of ~ 400MB/s at start (I assume this is fill-up of some cache). Using a RAID0-array of two disks I get 382MB/s, which seems to me correct scaling.
However if I try to add more disks to my RAID-array I am stuck at ~400MB/s.
What can be the cause of that?
Tools used: HD Tune and h2benchw (pretty much consistent in results)
System:
ASUS P6T6 WS Revolution
12GB memory
Intel i7 920 processor @ 2.67GHz
NVIDIA Quador FX 370
Microsoft Windows Vista 64bit
My guess is that there is some bottleneck either in the RAID controller or in the 8-lane PCI-e bus ???
I tried to switch PCI-e slots, checked all drives individually, played with cache settings at the controller and used different stripe sizes. I do not see any PCI-e settings in the motherboard BIOS. Only two PCI-e slots are occupied, one by the graphics card, one by the RAID controller.
Thanks for any hints where to look or what further tests I could do!
Ingmar.
Reply to ihartl
well each port on that card can do 3gb/s which is 375MB/s if i'm not mistaken.
so if you have 4 drives connected to one port of that card, the most throughput you'll get is 375MB/s. if you utilize both ports of the card (say, 6 drives, RAID 0) max throughput would double to 750MB/s.
unless i'm missing something.
Reply to brianhj
Even by using both ports I only get 400MB/s (7-disk RAID 0). I the meantime I got some slight improvement when using the newest Adaptec Vista drivers and the newest Adaptec BIOS.
Now the average write speed to a 7-disk (X25-E) RAID-0 array is 465.7MB/s,
The write speed to a 3-disk RAID-0 array (using the same port on the adaptec controller) is 456.5 MB/s, for two disks I get 385.7MB/s average.
So using more than 3 disks and using more than 1 port on the controller gives no significant improvement in throughput. I am still puzzled.
Reply to ihartl
Why don't you use the onboard sata controler from your motherboard with 6 disks ? So you can bypass the pci-e bottelneck or pci-e specific driver problems and see how nice the southbridge is ?
Reply to lma111
Hello
I wanted to share with you my experience.
I run a 5805 with 4 X25-E on a Linux 2.6.31 64bit box, with a dual quad-core and 8GB of RAM. Your setup is more powerful so I assume it is not a bottleneck.
A few bandwidth figures:
- the 5085 is a PCIe 8x card, the PCIe bandwidth is 8x250MB/s = 2GB/s
- I didn't find the official bandwidth of the SFF8087 port, http://www.tomshardware.com/forum/ [...] dable-soho claims 24Gbit/s
- an X25-E reaches 250MB/s, which is 2/3 of the bandwidth of each SATA link (3Gbit/s)
- Adaptec claims that the 5085 reaches 1.2GB/s
So to me, the first bottleneck is actually the 5805 card itself.
I reach 1GB/s at most in the following configuration:
- 2 disks on each SFF8087
- RAID0 with default settings, configured through the menu at boot, not the software provided by Adaptec
Note that 1GB/s is pretty much the scaling of 4 X25-E at 250MB/s. I am only interested in RAID0, I didn't benchmark other configurations.
The benchmark procedure is to read and write 2GB of data, for various block sizes, at the block level (not the filesystem level), between the RAID (/dev/sda) and the RAM (/dev/shm). It kills any data on the disk, of course, don't blame me if you lose anything.
In a shell:
for bs in 64 128 256 512 1024 2048 4096 8192 16384 32768 65536 131072 262144 524288 1048576 2097152 4194304 8388608 16777216 33554432 67108864 134217728 268435456 536870912 1073741824; do dd if=/dev/sda of=/dev/shm/junk bs=$bs count=$((2147483648/$bs)); done
For writing tests, switch "if" and "of" values in the previous command.
The throughput increases from ~80MB/s at bs=64 to a little less than 1GB/s at 16384.
It stays at 1GB/s for the following bs values: 32768 65536 131072 262144 524288 1048576
Then it decreases to 600MB/s for blocksizes higher than 2097152
One remark: the throughput is more than halved if I put 4 disks on a single SFF8087 (drops to 400MB/s at most).
I hope these indications will help you solve your problem. I would also appreciate if somebody could confirm my results, of course.
Thanks
Sylvain
Reply to kag
There are 1914 identified and unidentified users. To see the list of identified users, Click here.
Ads
Latest best answer
Connecting a Laptop Hard disk directly to Desktop (SATA)
By RetiredChief, 1 hour ago:
fantastik250 - Sata interface is only for data. Does not adjust any voltages. power is...
Best offers
Top experts
