Tom's Hardware > Forum > Storage > Hard Disks > Hard drive problem?
Hard drive problem?
Forum Storage : Hard Disks - Hard drive problem?
can i simultaneously use my iomega external hard drive on both a pc and mac and continue to go back and forth between a pc and mac? is that possible, or will i have to use it for one or the other only?
Sponsored Links
Use it on each one. Select a file system compatible between both like ext2.
Ext2 can read by both Windows and Mac.
Macs can read NTFS with special software.
Reply to evongugg
what exactly is ext2?
Reply to wmendez
http://www.lmgtfy.com/?q=ext2
I'm guessing you want the third/soundforge link. You might also want to wait more then 6min between postings.
------------------------------ The voice of REASON
Do NOT feed the TROLLS!
Always a DEMON!
Reply to 4745454b
There are 567 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
