Motherboard "forgets" ONLY overclock settings after power off
- P5WDH Deluxe cmos settings wrong after power off - Forum
- EThernet Led suddenly goes off and it will turn on only after the power to cpu is turned off and turned on. - Forum
- Problem with either R9 270 or Monitor - vertical lines after windows sets screen power off - Forum
- ASUS M3A78-CM BIOS settings get reset to default after power cut or power off.... - Forum
- What does this red light mean after I turn off the motherboard power directly? - Forum
- Power supply clicking noise - only on start up, only after long time switched off Forum
- Gigabyte A55 motherboard - overclock settings lost and cannot re-enable after PC freeze Forum
- Motherboard supplies PCIe connector with power only after CMOS reset? Forum
- SolvedMotherboard powers on, then shuts off after a second Forum
- Core i7 920 Overclock FAIL.. after long power off Forum
- PC Only powering up by PSU Switch, but turns off after a few Seconds Forum
- BIOS set to ALWAYS OFF but PC boots up after power is back Forum
- Overclocking past the power limit set by motherboard??? Forum
- Power setting keeps resetting monitor off to 20 minutes after restart Forum
- My screen turns off after 20 min even with 'never' power setting Forum
- More resources
Read discussions in other Overclocking categories
