Tom's Hardware > Forum > Motherboards & Memory > Memory > 4gb G skill 1066 running slow....advice?
Forum Motherboards & Memory : Memory - 4gb G skill 1066 running slow....advice?
i have 4 gigs of G-Skill 1066 ddr2, they register at about 800mhz... ive been using them as is but id like to get them up to full speed
i'm not sure what voltage its at right now since im not home to check but what do others have their settings are at to achieve 1066 mhz?
Is it more than voltage settings?
IP35 pro xe
q6600
corsair 550Wpsu
Sponsored Links
There is no standard for DDR2 1066 - 800 is the highest speed. What you have amounts to 'Factory Overclockable' memory. If it isn't on the package, go to Gskill's website and look up the model number. It'll tell you the timings and voltages required. Once you have that, go into your Bios and set them accordingly.
------------------------------ Which Chip? Well, it depends on which set of thieving b@stardz you choose to support: The ones who use insider trading to enrich themselves while running their company into the ground? Or the ones who illegally pay vendors to not support the first group?
Reply to Scotteq
There are 864 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
