Tom's Hardware > Forum > Overclocking > Cooler and Heatsinks > Water additive/coolant
Forum Overclocking : Cooler and Heatsinks - Water additive/coolant
Hi,
So I've come to the last part of planning for my watercooling and I'm stuck.
What coolant do I use, I'm 90% stirring closer to FeserOne UV Black Coolant as it's an all in one thing, but I heard this isn't good.
I'm very very basic especially on the additive and I don't know what to do, can you recommend me something?
BTW the kit I'm getting is the Swiftech H20 220 Apex Ultima.
Sponsored Links
distilled water is preferred or de-ionized if thats all you can get, then u need a anti-bacterial or anti-algae solution with it then also sum dye to make it look cool it costs nothing compared to the fesser stuff and is just as good
Reply to richardscott
Distilled water and 1-2 drops of Petras PHN Nuke is all you need. Pretty cheap too. If you want color or UV, Feser makes okay stuff.
Reply to Conumdrum
Quote :
+1. Distiled water + PT Nuke works well. You can also use KillCoils to control bacteria.
Message edited by Shadow703793 on 04-15-2009 at 02:04:47 PM
------------------------------ http://farm3.static.flickr.com/2617/3815217176_0a5be7955d_o.gif
http://farm4.static.flickr.com/3553/3818083596_1a772f7162_o.gif
Reply to Shadow703793
There are 537 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
