Tom's Hardware > Forum > Overclocking > Cooler and Heatsinks > Need fans for my Cooler Master 690
Forum Overclocking : Cooler and Heatsinks - Need fans for my Cooler Master 690
I need an 80x15mm fan (behind motherboard)
and I can put up to 4 more fans either 120mm or 140mm
I'm using my computer for gaming so I want a cool computer.
What are the best fans to go with?
Message edited by offspringfan23 on 04-06-2009 at 08:29:47 AM
Sponsored Links
Get these 120MM...Silent and they do a great job...
http://www.newegg.com/Product/Prod [...] 6835185004
Else something fancy...
http://www.newegg.com/Product/Prod [...] 6835103022
Well xthekid has the same case and runs an i7 in it...So he can help you better for which slots to you as adding a lot of fans can increase the noise level, which might irritate you...
Message edited by gkay09 on 04-06-2009 at 08:47:40 AM
Reply to gkay09
I have been pretty happy with antec tri-cool 120's even though they only connect via 4 pin molex.
Reply to DiscoDuck
I found an 80x15mm that sould work nicely behind the motherboard, how's this:
http://www.newegg.com/Product/Prod [...] 6835226001
Reply to offspringfan23
There are 836 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
