I'm not sure if this is the correct spot for this question...sorry if it isn't.
I have an older 1.2GHz Athlon (VIA chipset, K7V board, I think). Comp was put together by someone that sold it to me on eBay several years ago, and it's been great until recently.
I started having random reboots and WoW gave me an error that's associated with bad RAM. I downloaded a MS diagnostic to confirm. Replaced the bad stick of RAM about a month ago.
After replacing the RAM, the comp wouldn't boot. The plug that went into the motherboard from the power supply was discolored, so hubby pulled a supply out of another comp and switched them out. The only other thing that was odd at that point was that one of my harddrives wasn't being recognized (not the boot drive).
He hooked everything back up, and everything was great until I powered the comp off. I couldn't get it to come on the next morning. It'd go part way through boot up, and then shut off, and the power light would flash. After unplugging the comp for a bit, I was able to get it to power up. Anytime the comp was turned off completely, it'd take many tries of unplugging/replugging/booting to get it to start. When I've pressed "restart" from Windows XP it restarts without a problem. I've just left the comp on for the last 3-4 weeks, to avoid the power up problem.
We had a brief power failure this morning, and I'm stuck trying to get the comp to turn on...so far no luck. Are there some particular things that we should look at for the problem? A friend suggested that the motherboard was fried, but I can't believe that the comp would have worked so well for weeks (as long as it wasn't completely powered down) if that were the case. I'm hoping it might be something affected when the power supply or RAM was changed out.
Thanks in advance for any help you can give.
