So I just finished up my new computer the other day, and since then, have been plagued by OpenGL errors in any game I try to run. I have tried pretty much every compatible version of drivers, not to mention reinstalling them time after time after time. I've also tried Driver Cleaner Pro -- no luck. Google has pretty much failed me on this one.
I'm totally stumped, and I'd really appreciate it if someone could help me out. Here's a printout of Quake 4's error logs when I try to run it:
Quote :
Winsock Initialized
Found interface: {A1695BEB-3745-4BE9-8289-FDF3E57950BD} Intel(R) PRO/1000 GT Desktop Adapter - 24.86.194.238/255.255.252.0
Sys_InitNetworking: adding loopback interface
engine using MMX & SSE & SSE2 & SSE3 for SIMD processing
enabled Flush-To-Zero mode
enabled Denormals-Are-Zero mode
--------- Initializing File System ----------
Loaded pk4 CProgram Files/id Software/Quake 4/q4base/fate.pk4 with checksum 0xe4980697
Loaded pk4 CProgram Files/id Software/Quake 4/q4base/game000.pk4 with checksum 0xb3abe28c
Loaded pk4 CProgram Files/id Software/Quake 4/q4base/game100.pk4 with checksum 0x74b379d9
Loaded pk4 CProgram Files/id Software/Quake 4/q4base/game200.pk4 with checksum 0xa3c810d9
Loaded pk4 CProgram Files/id Software/Quake 4/q4base/map_l4ctf2_beta3.pk4 with checksum 0xf0f388c3
Loaded pk4 CProgram Files/id Software/Quake 4/q4base/map_l4dm1_1.pk4 with checksum 0xfd6a9089
Loaded pk4 CProgram Files/id Software/Quake 4/q4base/map_l4dm2_1.pk4 with checksum 0x32c4391c
Loaded pk4 CProgram Files/id Software/Quake 4/q4base/map_tmp02.pk4 with checksum 0xff9361c1
Loaded pk4 CProgram Files/id Software/Quake 4/q4base/map_wvwq4dm1.pk4 with checksum 0x5069e74f
Loaded pk4 CProgram Files/id Software/Quake 4/q4base/pak001.pk4 with checksum 0xf2cbc998
Loaded pk4 C:/Program Files/id Software/Quake 4/q4base/pak002.pk4 with checksum 0x7f8d80d1
Loaded pk4 C:/Program Files/id Software/Quake 4/q4base/pak003.pk4 with checksum 0x1b57b207
Loaded pk4 C:/Program Files/id Software/Quake 4/q4base/pak004.pk4 with checksum 0x385aa578
Loaded pk4 C:/Program Files/id Software/Quake 4/q4base/pak005.pk4 with checksum 0x60d50a1d
Loaded pk4 C:/Program Files/id Software/Quake 4/q4base/pak006.pk4 with checksum 0x9099ed11
Loaded pk4 C:/Program Files/id Software/Quake 4/q4base/pak007.pk4 with checksum 0xaf301fff
Loaded pk4 C:/Program Files/id Software/Quake 4/q4base/pak008.pk4 with checksum 0x4ac6f6d9
Loaded pk4 C:/Program Files/id Software/Quake 4/q4base/pak009.pk4 with checksum 0x36030c7d
Loaded pk4 C:/Program Files/id Software/Quake 4/q4base/pak010.pk4 with checksum 0x4b80fbda
Loaded pk4 C:/Program Files/id Software/Quake 4/q4base/pak011.pk4 with checksum 0x8acf4cfa
Loaded pk4 C:/Program Files/id Software/Quake 4/q4base/pak012.pk4 with checksum 0xbe4120b0
Loaded pk4 C:/Program Files/id Software/Quake 4/q4base/pak013.pk4 with checksum 0x6ad67f40
Loaded pk4 C:/Program Files/id Software/Quake 4/q4base/pak014.pk4 with checksum 0xee51cd59
Loaded pk4 C:/Program Files/id Software/Quake 4/q4base/pak015.pk4 with checksum 0xf5bf4e0c
Loaded pk4 C:/Program Files/id Software/Quake 4/q4base/pak016.pk4 with checksum 0x2196f58c
Loaded pk4 C:/Program Files/id Software/Quake 4/q4base/pak017.pk4 with checksum 0x91118a35
Loaded pk4 C:/Program Files/id Software/Quake 4/q4base/pak018.pk4 with checksum 0x98a14f03
Loaded pk4 C:/Program Files/id Software/Quake 4/q4base/pak019.pk4 with checksum 0xbc82ac79
Loaded pk4 C:/Program Files/id Software/Quake 4/q4base/pak020.pk4 with checksum 0xce74cda5
Loaded pk4 C:/Program Files/id Software/Quake 4/q4base/pak021.pk4 with checksum 0x2ba6e70c
Loaded pk4 C:/Program Files/id Software/Quake 4/q4base/pak022.pk4 with checksum 0x4e390eec
Loaded pk4 C:/Program Files/id Software/Quake 4/q4base/q4cmp_pak001.pk4 with checksum 0xd0813943
Loaded pk4 C:/Program Files/id Software/Quake 4/q4base/q4ctf1_norg_perf.pk4 with checksum 0xf20cbebe
Loaded pk4 C:/Program Files/id Software/Quake 4/q4base/q4ctf2_perfix.pk4 with checksum 0xc2e424d5
Loaded pk4 C:/Program Files/id Software/Quake 4/q4base/q4ctf3b_final.pk4 with checksum 0x9c5584c4
Loaded pk4 C:/Program Files/id Software/Quake 4/q4base/q4ctf6whore_final.pk4 with checksum 0xa5706a3d
Loaded pk4 C:/Program Files/id Software/Quake 4/q4base/q4w2b.pk4 with checksum 0xc1ab822b
Loaded pk4 C:/Program Files/id Software/Quake 4/q4base/q4wcp14_perf.pk4 with checksum 0x1799668f
Loaded pk4 C:/Program Files/id Software/Quake 4/q4base/q4wcp18.pk4 with checksum 0x93f17dc9
Loaded pk4 C:/Program Files/id Software/Quake 4/q4base/q4wcp1_perf_beta_c.pk4 with checksum 0xa8804b8d
Loaded pk4 C:/Program Files/id Software/Quake 4/q4base/q4wcp5_perf.pk4 with checksum 0x688cc71c
Loaded pk4 C:/Program Files/id Software/Quake 4/q4base/q4wcp9_perf.pk4 with checksum 0x88575fd
Loaded pk4 C:/Program Files/id Software/Quake 4/q4base/q4wcp9fixed1.pk4 with checksum 0x355f647d
Loaded pk4 C:/Program Files/id Software/Quake 4/q4base/zpak_english.pk4 with checksum 0x5868f530
Loaded pk4 C:/Program Files/id Software/Quake 4/q4base/zpak_english_01.pk4 with checksum 0xd9f04b8b
Loaded pk4 C:/Program Files/id Software/Quake 4/q4base/zpak_english_02.pk4 with checksum 0x9dbd91fd
Loaded pk4 C:/Program Files/id Software/Quake 4/q4base/zpak_english_03.pk4 with checksum 0x2eb6ad8
Loaded pk4 C:/Program Files/id Software/Quake 4/q4base/zpak_english_04.pk4 with checksum 0xd3fefaa1
Loaded pk4 C:/Program Files/id Software/Quake 4/q4max/zz-q4max-game-082.pk4 with checksum 0x422cf46b
Loaded pk4 C:/Program Files/id Software/Quake 4/q4max/zz-q4max-media-082.pk4 with checksum 0x84855b3b
Addon pk4 C:/Program Files/id Software/Quake 4/q4base/q4ctf3b_final.pk4 with checksum 0x9c5584c4 is on addon list
Addon pk4 C:/Program Files/id Software/Quake 4/q4base/q4cmp_pak001.pk4 with checksum 0xd0813943 is on addon list
Addon pk4 C:/Program Files/id Software/Quake 4/q4base/map_wvwq4dm1.pk4 with checksum 0x5069e74f is on addon list
Addon pk4 C:/Program Files/id Software/Quake 4/q4base/map_l4dm2_1.pk4 with checksum 0x32c4391c is on addon list
Addon pk4 C:/Program Files/id Software/Quake 4/q4base/map_l4dm1_1.pk4 with checksum 0xfd6a9089 is on addon list
Current search path:
C:/Program Files/id Software/Quake 4/q4max/zz-q4max-media-082.pk4 (628 files)
C:/Program Files/id Software/Quake 4/q4max/zz-q4max-game-082.pk4 (11 files)
C:/Program Files/id Software/Quake 4/q4base/zpak_english_04.pk4 (3 files)
C:/Program Files/id Software/Quake 4/q4base/zpak_english_03.pk4 (4 files)
C:/Program Files/id Software/Quake 4/q4base/zpak_english_02.pk4 (21 files)
C:/Program Files/id Software/Quake 4/q4base/zpak_english_01.pk4 (1 files)
C:/Program Files/id Software/Quake 4/q4base/zpak_english.pk4 (3457 files)
C:/Program Files/id Software/Quake 4/q4base/q4wcp9fixed1.pk4 (50 files)
C:/Program Files/id Software/Quake 4/q4base/q4wcp9_perf.pk4 (19 files)
C:/Program Files/id Software/Quake 4/q4base/q4wcp5_perf.pk4 (12 files)
C:/Program Files/id Software/Quake 4/q4base/q4wcp1_perf_beta_c.pk4 (114 files)
C:/Program Files/id Software/Quake 4/q4base/q4wcp18.pk4 (16 files)
C:/Program Files/id Software/Quake 4/q4base/q4wcp14_perf.pk4 (19 files)
C:/Program Files/id Software/Quake 4/q4base/q4w2b.pk4 (10 files)
C:/Program Files/id Software/Quake 4/q4base/q4ctf6whore_final.pk4 (15 files)
C:/Program Files/id Software/Quake 4/q4base/q4ctf2_perfix.pk4 (15 files)
C:/Program Files/id Software/Quake 4/q4base/q4ctf1_norg_perf.pk4 (29 files)
C:/Program Files/id Software/Quake 4/q4base/pak022.pk4 (14 files)
C:/Program Files/id Software/Quake 4/q4base/pak021.pk4 (89 files)
C:/Program Files/id Software/Quake 4/q4base/pak020.pk4 (11 files)
C:/Program Files/id Software/Quake 4/q4base/pak019.pk4 (1206 files)
C:/Program Files/id Software/Quake 4/q4base/pak018.pk4 (3 files)
C:/Program Files/id Software/Quake 4/q4base/pak017.pk4 (3 files)
C:/Program Files/id Software/Quake 4/q4base/pak016.pk4 (193 files)
C:/Program Files/id Software/Quake 4/q4base/pak015.pk4 (34 files)
C:/Program Files/id Software/Quake 4/q4base/pak014.pk4 (552 files)
C:/Program Files/id Software/Quake 4/q4base/pak013.pk4 (239 files)
C:/Program Files/id Software/Quake 4/q4base/pak012.pk4 (1081 files)
C:/Program Files/id Software/Quake 4/q4base/pak011.pk4 (5620 files)
C:/Program Files/id Software/Quake 4/q4base/pak010.pk4 (5539 files)
C:/Program Files/id Software/Quake 4/q4base/pak009.pk4 (1284 files)
C:/Program Files/id Software/Quake 4/q4base/pak008.pk4 (1289 files)
C:/Program Files/id Software/Quake 4/q4base/pak007.pk4 (1330 files)
C:/Program Files/id Software/Quake 4/q4base/pak006.pk4 (1343 files)
C:/Program Files/id Software/Quake 4/q4base/pak005.pk4 (1395 files)
C:/Program Files/id Software/Quake 4/q4base/pak004.pk4 (2249 files)
C:/Program Files/id Software/Quake 4/q4base/pak003.pk4 (1281 files)
C:/Program Files/id Software/Quake 4/q4base/pak002.pk4 (313 files)
C:/Program Files/id Software/Quake 4/q4base/pak001.pk4 (5837 files)
C:/Program Files/id Software/Quake 4/q4base/map_tmp02.pk4 (47 files)
C:/Program Files/id Software/Quake 4/q4base/map_l4ctf2_beta3.pk4 (158 files)
C:/Program Files/id Software/Quake 4/q4base/game200.pk4 (9 files)
C:/Program Files/id Software/Quake 4/q4base/game100.pk4 (2 files)
C:/Program Files/id Software/Quake 4/q4base/game000.pk4 (2 files)
C:/Program Files/id Software/Quake 4/q4base/fate.pk4 (11 files)
game DLL: 0x0 in pak: 0x0
Addon pk4s:
C:/Program Files/id Software/Quake 4/q4base/map_l4dm1_1.pk4 (7 files)
C:/Program Files/id Software/Quake 4/q4base/map_l4dm2_1.pk4 (22 files)
C:/Program Files/id Software/Quake 4/q4base/map_wvwq4dm1.pk4 (45 files)
C:/Program Files/id Software/Quake 4/q4base/q4cmp_pak001.pk4 (119 files)
C:/Program Files/id Software/Quake 4/q4base/q4ctf3b_final.pk4 (17 files)
file system initialized.
------------ Initializing Decls -------------
Loading guides.... 68 loaded
310ms to load 1183k of material
61ms to load 44k of skin
154ms to load 734k of sound
2ms to load 1k of materialType
13ms to load 0k of lipSync
44ms to load 105k of playback
693ms to load 1707k of effect
-------- Initializing renderSystem ----------
Spawning back end thread...
...ok
using ARB renderSystem
renderSystem initialized.
Found default language English with VO
.... found additional language 'french' without VO
.... found additional language 'italian' without VO
.... found additional language 'spanish' without VO
696 strings read from strings/english_code.lang
1794 strings read from strings/english_guis.lang
5756 strings read from strings/english_lips.lang
5759 strings read from strings/english_mappack.lang
6235 strings read from strings/english_maps.lang
3 strings read from strings/french_mappack.lang
3 strings read from strings/italian_mappack.lang
3 strings read from strings/spanish_mappack.lang
Couldn't open journal files
execing default.cfg
couldn't exec editor.cfg
execing Quake4Config.cfg
couldn't exec autoexec.cfg
-------- Initializing Sound System ----------
sound system initialized.
--------------- R_InitOpenGL ----------------
Initializing OpenGL subsystem
...registered window class
...registered fake window class
...initializing QGL
...calling LoadLibrary( 'opengl32' ): succeeded
Couldn't find proc address for: wglGetExtensionsStringARB
Couldn't find proc address for: wglSwapIntervalEXT
Couldn't find proc address for: wglGetPixelFormatAttribivARB
Couldn't find proc address for: wglGetPixelFormatAttribfvARB
Couldn't find proc address for: wglChoosePixelFormatARB
Couldn't find proc address for: wglCreatePbufferARB
Couldn't find proc address for: wglGetPbufferDCARB
Couldn't find proc address for: wglReleasePbufferDCARB
Couldn't find proc address for: wglDestroyPbufferARB
Couldn't find proc address for: wglQueryPbufferARB
Couldn't find proc address for: wglBindTexImageARB
Couldn't find proc address for: wglReleaseTexImageARB
Couldn't find proc address for: wglSetPbufferAttribARB
setting to: 1024 768
...calling CDS: failed, DISP_CHANGE_FAILED
...trying next higher resolution:
...no high res mode found
Shutting down OpenGL subsystem
...wglMakeCurrent( NULL, NULL ): failed
...shutting down QGL
...unloading OpenGL DLL
...initializing QGL
setting to: 640 480
Fatal Error: Unable to initialize OpenGL
--------------- BSE Shutdown ----------------
idRenderSystem::Shutdown()
As well as dxdiag when testing Direct3D:
Quote :
Direct3D 7 test results: Failure at step 39 (SetDisplayMode to 640x480x16): HRESULT = 0x80004001 (Not implemented)
Direct3D 8 test results: Failure at step 8 (Creating 3D Device): HRESULT = 0x88760827 (error code)
Direct3D 9 test results: Failure at step 8 (Creating 3D Device): HRESULT = 0x8876086c (error code)
Everything else on my computer is fine -- even movies. I've also had games work after reinstalling several times, but only for a few startups. Also, this problem started right off the bat after first installing the video drivers. Can anyone help me out here?
