Are these PC parts compatible?
These are the parts that I am going to order from newegg.com.
Motherboard-BIOSTAR A770 A2+
http://www.newegg.com/Product/Product.aspx?Item=N82E16813138106
CPU-AMD Athlon 64 X2 4600+ Windsor 2.4GHz
http://www.newegg.com/Product/Product.aspx?Item=N82E16819103064
Ram-WINTEC AMPX 4GB
http://www.newegg.com/Product/Product.aspx?Item=N82E16820161183
Video Card-SAPPHIRE 100236L Radeon HD 3650
http://www.newegg.com/Product/Product.aspx?Item=N82E16814102726
Sound Card-ENCORE ENM232-8VIA
http://www.newegg.com/Product/Product.aspx?Item=N82E16829180004
Network Card-TRENDnet TE100-PCIWN
http://www.newegg.com/Product/Product.aspx?Item=N82E16833156107
Hard Drive-Seagate Barracuda 7200.10
http://www.newegg.com/Product/Product.aspx?Item=N82E16822148261
Optical Drive-SAMSUNG SH-S203N
http://www.newegg.com/Product/Product.aspx?Item=N82E16827151154
Memory Card Reader-nMEDIAPC ZE-C68
http://www.newegg.com/Product/Product.aspx?Item=N82E16820132016
Power Supply-Rosewill RV430-2-FRB-S
http://www.newegg.com/Product/Product.aspx?Item=N82E16817182064
Case Fan-MASSCOOL FD08025S1M4
http://www.newegg.com/Product/Product.aspx?Item=N82E16835150007
FAn Filter-GENERIC 80MM FAN FILTER
http://www.newegg.com/Product/Product.aspx?Item=N82E16811999206
CPU Fan&Heatsink-ARCTIC COOLING ACF64LP
http://www.newegg.com/Product/Product.aspx?Item=N82E16835186019
Case-Sunbeam AC-T
http://www.newegg.com/Product/Product.aspx?Item=N82E16811166006
This is the first time I'm building a computer, and I am not sure that the power supply is right, but I think everything else will work fine. I'm afraid that some parts will not be compatible with the motherboard or there is a issue with one of the parts. I am going to run windows XP on it. Any suggestions or comments would be great. :)
10 answers Last reply
More about parts compatible
  1. What is the system going to be used for?
    If your not gaming you can use a board with onboard video
    You do not need a network card, its on the board already.
    The psu is not highly rated, but should run it fine, if you can get a FSP,Antec,OCZ,seasonic or corsair(there are others as well)
  2. @OP:
    Stay away from motherboards made from BIOSTAR, also WINTEC RAM, and Rosewill PSUs.
    1. What is your budget?
    2. Do you plan to OC?
    3. What will this PC be used for? (ie gaming, office work, Photoshop,etc)
  3. I suggest an upgrade to the PSU.
    StealthXStream 600W costs $60 after rebate and free shipping. Higher quality and much more powerful than that Rosewill (which is $42 after shipping).
    http://www.newegg.com/Product/Product.aspx?Item=N82E16817341010
    If you're gaming, let's talk about a better video card. For about $150 or $200 you can have something very good, and that StealthXStream will support it.
  4. I am not a hardcore gamer, but I do play some games (Fifa 08). This is mostly for office work and some light gaming. (The most demanding game I would play is Half-Life 2) I'm trying to keep this under $600, and I don't think I would OC. I will get another psu.
    Are there any suggestions for what brands to get for the motherboard and ram?
    Thanks for the comments.
  5. I would look into some of the Asus and Gigabyte boards there are some good prices on newegg.
    memory wise, corsair value select has worked well for me on budget builds.
  6. There's a nice deal at zipzoomfly, GameXStream 600W for $43 after rebate. The GameXStream series is a bit better than StealthXStream.
  7. I think I will go with the RAIDMAX HYBRID 2 RX-530SS for the psu.
    http://www.newegg.com/Product/Product.aspx?Item=N82E16817152028
    I don't know if ELITEGROUP is a good brand, but their ECS A780GM-A motherboard seems good.
    http://www.newegg.com/Product/Product.aspx?Item=N82E16813135075
    For the ram, I'm going to go with the CORSAIR TWIN2X4096-6400C5 4GB.
    http://www.newegg.com/Product/Product.aspx?Item=N82E16820145184
    Will these parts work with what I already have?
    thanks again
  8. The MB and RAM look good. The Raidmax PSU is a tier 5 (i.e. bad). It's also rather weak, two rails at 18A+17A. It's 4enough for that 3650, but it won't be if you ever want a gaming card. You'd be better off with that GameXStream (tier 2, 4 rails of 18A each), even if it costs $3 more + shipping.
    http://www.zipzoomfly.com/jsp/ProductDetail.jsp?ProductCode=316504&ps=hw8
  9. The GameXStream looks like a good deal, but I can only order from newegg because of shipping. (I live in Alaska)
    Would the Thermaltake TR2 W0070RUC or the APEVIA ATX-CW500WP4 be okay?
    Thermaltake-http://www.newegg.com/Product/Product.aspx?Item=N82E16817153023
    APEVIA-http://www.newegg.com/Product/Product.aspx?Item=N82E16817148027
  10. ^Out of the two, go with Thermaltake.
New Build Systems Product
