Hey All,
I got a update on the OC. After not as much tweaking as I expected I am currently running my e7400 at 3.5ghz (333x10.5 1.26v). It has been running Prime95 for about 19 hours so far and seems to be holding strong. The temp is staying right at 49-52C according to a few different temp monitors. I was first wondering if I should try Orthos after this as well? I didnt know if most people run both or shiuld I just assume it is stable after 24 hours of Prime95?
Now to move on, from what I have found around the web my voltage seems a lot lower than most other people running at same/similar speeds. And I havent even tried to lower the voltage than what it is. I just upped it to that when I started OC'ing and left it, so I am sure I might be able to lower the voltage and keep it stable and even get it running a little bit cooler.
Now here is my question, since I seem to be fine as far as the heat and great for voltage, you guys think I should leave it or maybe try for 4.0ghz? I ask because like I said, a lot of other people around the web that are running 3.5ghz with different fsb and multi. setups and seem to have to have their voltage around 1.30 or above, and that is with the voltage tweaked at the lowest possible voltage that is stable. Like I said, I havent messed with the voltage at all as far as lowering it to see if it is stable at lower voltages. So should I try for 4.0ghz?
Another thing that I want to consider is will I really see that much of a difference in perfomance? I know that 500mhz is 500mhz. But I ask with my system setup, is my graphics card going to be a bottleneck for the processor if I can hit 4.0ghz? Same thing with the ram, but once I get the processor where I want it and stable, I plan on OC'ing the ram as well. I have Memtest86 to stress the ram after OC.
I know that I dont have the top of the line graphics card by any means. I ran Crysis last night and with the processor at 3.5ghz and my graphics card OC'ed some, I was seeing about a 5 to 15fps increase given the situation during gameplay at high settings and 1920x1080 than I was with no OC. Also, with the benchmark, I ran an average of 34.45fps at high settings and 1680x1050, now I am running basically the same average (maybe .xx off) at high settings and 1920x1080. I also plan to run FurMark and rthdribl to make sure my graphics card OC is stable.
Another thing is by the end of the year at the lastest I plan on getting another gts 250 and sli them with a new power supply. I also might pick up another 4gb of ram once Windows 7 comes out to give me 8gb. (know it is not needed though). So should this play into me just being happy with 3.5ghz right now, and then once I get the other graphics card and new poer supply, try for 4.0ghz?
Any help and suggestions on this would be awesome. So just a review of my questions:
- Should I try to lower my voltage and retest if the system goes right now, 24 hours fine on Prime95?
- Should I try to run Orthos as well?
- If Prime95 checks out, should I try for 4.0ghz or wait untill I get another gts 250 and new power supply?
- Will the perfomace gain as my system sits right now be worth running the processor at 4.0ghz (gpu or ram bottleneck)?
Thanks for any info guys!
Chris Stickles
