Tom's Hardware > Forum > Homebuilt Systems > New System Build > first build problems...
Forum Homebuilt Systems : New System Build - first build problems...
This is my first build...
Components:
ATX Ultra case
EVGA 650i Ultra mobo
Q6600 processor
4 x 1024 OCZ pc6400
BGF 650w psu
Seagate 250 w/sata
Sony dvd
HSI ATI 3680
I had everything installed but when I press the power button the cpu fan spins around about twice then stops. The orange/yellow led comes on and the green one blinks. There are no beeps but that doesn't mean I don't have that connected properly.
Any help is appreciated.
Thanks,
JG
Sponsored Links
Assuming cpu is in socket correctly... I would (with MB manual in hand) recheck all my connections. I have built 3 systems and never had a problem with installing MB Driver then Windows until my last build. I didn't read the MB manual carefully enough and follow the very exstensive MB/Bios setup instructions correctly. Windows installed but almost emmediately began failing. I ended up having to take my new system to Best Buy to have them sort it out. Very embarrassing. Months later I was updating my MB driver and actually read that portion of the manual that involved MB/BIOS setup. Felt pretty stupid... Good luck
Reply to kbrew929
There are 1208 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
